-   -   Opinions wanted (http://www.hotrodders.com/forum/opinions-wanted-63503.html)
willowbilly3 05-30-2005 02:51 AM
Opinions wanted
1 Attachment(s)
I have had this idea for a long time so Saturday I picked up a couple early 80s Ford aluminum aircleaner lids. I cleaned this one up a little with some B-12 and fine steel wool. Then just laid the old spinner on for the pic. First problem is with a stock wheel the front hub hits and holds it out just a little. I had thought I could mount them with the hubcap mounting thingy for the center screw like my 88 Merc has but that thing holds the cover out almost 2 inches. Maybe cut out the center for some sort of cone, or take it out to the hubcap bumps and use a dogdish cap. Any ideas? comments?
baddbob 05-30-2005 07:10 AM
Find a wheel with a little less backspacing and your clearance problems should be solved, Fab up a center mounted bracket for attachment similar to those found on the wirewheel covers of the eighties, you might also need 3 or 4 rim screws.
willowbilly3 05-30-2005 08:39 AM
That was pretty much what I was thinking except on the front of my rpu I don't want a wide or dished out rim.
crazy larry 05-30-2005 09:33 PM
looks good man'. :thumbup:
packratwrecker 05-31-2005 08:19 PM
May not be the look you are wanting, but what about cutting the center, and fitting in a GM rally sombero, then putting the spinners on them?
willowbilly3 06-01-2005 02:46 AM
I am still playing with it. I was thinking something like a dogdish center. I have a couple sets of early 50s Ford script caps. I need to find more aircleaner lids so I can experiment. Right now I have 2 but they are common, and most junkyards around here don't even charge for stuff like that.
