Opinions wanted - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-30-2005, 02:51 AM
willowbilly3's Avatar
Last journal entry: Body mods
Opinions wanted
I have had this idea for a long time so Saturday I picked up a couple early 80s Ford aluminum aircleaner lids. I cleaned this one up a little with some B-12 and fine steel wool. Then just laid the old spinner on for the pic. First problem is with a stock wheel the front hub hits and holds it out just a little. I had thought I could mount them with the hubcap mounting thingy for the center screw like my 88 Merc has but that thing holds the cover out almost 2 inches. Maybe cut out the center for some sort of cone, or take it out to the hubcap bumps and use a dogdish cap. Any ideas? comments?
Name:	ebay 5-26-05.jpg
Old 05-30-2005, 07:10 AM
Find a wheel with a little less backspacing and your clearance problems should be solved, Fab up a center mounted bracket for attachment similar to those found on the wirewheel covers of the eighties, you might also need 3 or 4 rim screws.
Old 05-30-2005, 08:39 AM
That was pretty much what I was thinking except on the front of my rpu I don't want a wide or dished out rim.
Old 05-30-2005, 09:33 PM
crazy larry's Avatar
Last journal entry: better comparison before and after shots
looks good man'.
Old 05-31-2005, 08:19 PM
packratwrecker's Avatar
Too many hobbies!
May not be the look you are wanting, but what about cutting the center, and fitting in a GM rally sombero, then putting the spinners on them?
Old 06-01-2005, 02:46 AM
I am still playing with it. I was thinking something like a dogdish center. I have a couple sets of early 50s Ford script caps. I need to find more aircleaner lids so I can experiment. Right now I have 2 but they are common, and most junkyards around here don't even charge for stuff like that.
Devilbiss FinishLine Spray gun opinions wanted rodnok1 Body - Exterior 5 11-17-2006 06:07 AM
Suspension choices, opinions wanted, lets talk theHIGHLANDER Suspension - Brakes - Steering 7 05-20-2005 01:34 PM
305 SBC buildup - opinions wanted Gametech Engine 15 04-10-2005 12:08 AM
Pontiac headers - opinions wanted scottgto Engine 4 09-30-2003 07:41 AM
opinions wanted Lightspeed Body - Exterior 12 10-07-2002 06:38 AM
