Opinions on water temp gauge - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-13-2011, 10:15 PM
bigdog7373's Avatar
Of course it's fast
Should i use electric or mechanical? Where is the best place to measure temperatures from? I was thinking at the rad inlet.
Old 12-13-2011, 10:57 PM
327NUT's Avatar
To each his own I reckon, I'm partial to mechanical gauges and I run them from the front port of the intake manifold. A good quality gauge, elec. or mech will work just fine.
Old 12-14-2011, 07:25 AM
Any good gauge is fine. Taking the reading from anywhere on the radiator is not.
I always put the sensor in the cylinder head if at all possible with the intake the second choice. I have seen engines loose the coolant and melt with the gauge in the intake and in the radiator is much worse. What happens is the heads get very hot but the intake and especially the radiator may not be that hot because the coolant no longer flows over the sensor.
Anything downstream from the thermostat is almost useless because a stuck thermostat will cook the motor and never warm the water in the thermostat housing or radiator.
Old 12-14-2011, 06:37 PM
11echo's Avatar
Old Guys Rule!...EVERYTHING!
I'd have to second the mechanical gauge! It's nice not to have to worry about electrical issues too, when your worried about the true temp. of your engine.
Old 12-14-2011, 07:43 PM
bigdog7373's Avatar
Of course it's fast
Here's what im working with basically. See any place at first sight that would be good to measure from?
Inoperative Water Temperature Gauge dasyhard Electrical 7 08-26-2011 06:13 AM
Checking Accuracy of Water Temperature Gauge kbuhagiar Engine 5 11-15-2010 09:35 PM
Best place to put a water temp gauge sensor? enduro54 Hotrodding Basics 5 05-12-2009 07:17 PM
I give up...bouncing water gauge... rbomar Engine 28 06-22-2007 11:24 PM
Bouncing water temp gauge... rbomar Engine 7 05-21-2007 05:50 PM
