Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Optimizing V6 performance, Infront of a T-400 TRANS.
  #18 (permalink)
Old 06-07-2012, 11:21 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by 0trbo4myCHEVUICK
thx cobalt.. went with your advice and got the stock tc.. sure it'l work out! Am i gonna have to get a custom driveshaft? Is there any way to make up for the 1/8" adapter plate? grind the yoke down?
There is enough engagement between the output shaft and yoke to compensate for the thickness of the adapter plate so you don't need to do anything to the driveshaft. I would be sure the U-joints are good since you have it out anyway.
Be sure to use the washer/spacers between the flexplate and torque converter to space it properly to compensate for the adapter thickness. That should be covered in the instructions.
