You obviously think I'm better at fabrication than I really am!
Somebody else did most of the bodywork on my car so far This is my first attempt on some scrap chassis pieces Chassis is approx 2mm thick Wire is 0.6mm Wire speed is 7 Power settings (from left to right) were 2 then 3 then 4 ![]() First weld looks too high with no penetration Second weld looks better, but probably still too high and thin Third weld started to spit What do you thunk I should adjust? |
Hopefully these pictures are a little better - I've had to take them with my iphone
Here's the same picture as before, hope it's not as fuzzy I've made sure my thumb is in the photo so you can gauge dimensions So here goes again..... Wire speed 7 Power settings 2, 3, 4 ![]() I've turned the wire speed up to 8 in this next picture Power settings are 2 and 3 ![]() I went a little too slow at the start of the first weld and blew through it a bit Overall, I think Wire Speed 8 and Power setting 3 is about right for this one What do you think? Would those settings be right for lap welding two pieces like this together? |
Im certainly NOT a welder, but it looks to me like you may be making a straight line? Try making small circles and pushing your puddle like that, so you get what looks like a small row of coins.
Like I said, I am no welder. Car is wicked by the way. |
Yeah, just welding in a straight line so far
I've seen the 'V' and 'Circle' motions, think i'll be trying my hand at that next time around And thanks for the compliments too - Still deciding whether to paint it Red or Yellow |
| What is the optimum distance for mufflers? | juiced66malibu | Engine | 2 | 10-11-2007 03:33 AM |
| door edges and panel gaps | robs ss | Body - Exterior | 4 | 07-11-2007 07:45 PM |
| Panel Gaps | Drides | Body - Exterior | 6 | 03-24-2006 08:16 PM |
| optimum timing curve | fiscus | Engine | 1 | 08-04-2005 05:36 PM |
| Optimum gear ratio | 406chevelle | Transmission - Rearend | 6 | 02-29-2004 08:13 PM |
