Options Options - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-13-2006, 03:22 PM
Options Options
Hey fellas,
I have a 73 vette with the stock 350 sb. I have added an Edelbrock performer intake and 650 cfm carb + ceramic coated headers. I have approx $3K that I would like to put into her this winter. This is what I was considering but I would value any input. Thanks.
Edelbrock Aluminum Heads Approx. $1,000
Add A/C ?????
New Cam $150
HEI dist w/ mechanical tac $400
Aluminum Radiator $450
Old 08-14-2006, 12:01 AM
Originally Posted by ffcagle34
Hey fellas,
Add A/C ?????
New Cam $150
If you can do the work, I would recommend a built 383 stroker short block, your choice of flat tappet cam installed and degreed. This will cost about $2300. Add the aluminum heads and distributor and you will be over your target of $3,000.
I run a stock brass BB 4 core radiator and a Permacool 16" electric fan on my '76 'vette without problems.
Old 08-16-2006, 07:30 PM
Thanks glen. I just want to work a little on the top end right now although I have considered a stroker for awhile now.
Further fine tuned my list:
Edelbrock Performer RPM Aluminum heads
???????????????64 or 70cc???????????????
(73 vette came with 8.5:1 comp ratio)
Comp Cam Magnum 280H Hydraulic flat tappet
?????????????too big?? should I just go with the 270H?????
I want it to be strong but I do not want vaccum problems.
Scratch the aluminum radiator at this time.
Thanks for reading and any input and/or affirmation on my plan.
Old 08-16-2006, 09:44 PM
firestone's Avatar
http://teamrfc.gospelcom.net
The performer RPM heads are not a bad choice for you, they should perform pretty well. I realize that this is spending money twice, but I think a performer RPM intake would work alot better with those heads and the cam you are looking at. The performer is not bad, it is just more for lower end power than the cam that you are looking at and what the heads are capeable of doing. If you were going to go with the performer RPM heads, I would try to duplicate the crate motor below. The cam is a little larger than the one that you are looking at, but edelbrock claims that it should still provide good vacuum for accessories. In any case, I would stay away from the single pattern cams. If you like comp, I would consider the XE274H (230 236 @.050 .490 lift). Also, with the edelbrock cam, I would run a 2500 stall minimum. Do you know what the combustion chamber volume is on the heads that you have now? With the aluminum heads, you could get away with 10:1+ compression, so I would recommend the smallest chamber that you can, and mabye even getting the new heads milled to 58cc if they would allow for that, but you better check into seeing if the heads can be milled like that first. If you are at 64cc now and you went to a set of 58cc heads, you would be looking at 9:1 which would be closer to that crate motor.
Here is the crate motor
http://www.jegs.com/webapp/wcs/store...tegoryId=10763
Here is the cam that is in that motor that makes 410 hp and 408 ft lbs
http://www.martelbrothers.com/catalo...ID-p-7148.html
Last thing, if you can hold on for the radiator, and spend $1450 on a set of heads, I would very highly recommend the AFR 180cc heads. They come fully ported from AFR which significantly increases their ability to make power.
Adam
Old 08-17-2006, 02:18 PM
Thank you for the input. What would make the AFR heads better than the Edelbrock? Fully ported?
Old 08-17-2006, 02:25 PM
www.araoengineering.com baddest heads ever. ,lot of money
Old 08-17-2006, 02:56 PM
firestone's Avatar
Porting is the main part of it, the more the heads flow, given the same size, the more power you can make, assuming that there is not something else wrong with the heads. The AFR 180's are 10cc larger than the performer RPM's, but they would still match your combo very well. On top of that AFR has just redesigned their heads and they are much better than they used to be and they were very good before. Below is some info on AFR as a company, and an article about the new heads. Also there are some provided flow numbers for the old heads. AFR makes a street ported head and a competition head. The street heads are $1450 a set and the Comp heads are $2000 a set. They say that the new street heads flow what the old comp heads did. Also, there are some flow numbers for the Performer RPM heads. This may not be an exactly head to head comparason since they were flowed on different benches, but you can still get the idea. Make sure that you order the heads from AFR, then you will be sure to get the new ones.
About AFR: this is worth reading if you are thinking about these heads
http://www.airflowresearch.com/about.php
This is an article about the new heads:
http://airflowresearch.com/articles/article113/A-P1.htm
Here are the flow numbers: Yours street heads would be similar to the comp heads here.
http://www.airflowresearch.com/180sbc_sh.php
Here are the flow numbers for the edelbrock heads from Chevy hi performance. The numbers that they got for the AFR heads is similar to the numbers that AFR publishes, so it may be a farily accurate comparason. the mid lift flow numbers are just as important if not more so than the high lift numbers and the AFR's outperform the edelbrocks even more so there. As a loose rule of thumb, you can assume a possibility of 2.2 hp gain per one CFM of flow. You will probably not gain quite this much, but comparing flow at .500 lift, the AFR's flow 23 cfm more theoretically, that would mean you could be looking at 50 more hp. That is a really hand wavy way to show the power difference, but it at least gives you a little bit of an idea.
http://www.chevyhiperformance.com/te...se/index4.html
One last thing, the AFR heads are on a waiting list of about 6-8 weeks. It is a pretty good wait, but I think it would be worth it.
Adam
Old 08-17-2006, 04:20 PM
Performer RPM intake is an excellent choice, but will not fit under stock 'vette hood when using the stock air cleaner. It will fit using a drop base cleaner. That is what I am running.
'52 Ford steering options slantws Suspension - Brakes - Steering 11 10-11-2005 04:55 PM
Column shifter options. Siggy_Freud Transmission - Rearend 3 03-04-2005 02:50 PM
Chop Top Options tundrafiend01 Body - Exterior 0 11-12-2003 11:10 PM
suspension options tuk Suspension - Brakes - Steering 1 09-06-2002 09:17 AM
