Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Options On SBC
Thread: Options On SBC
Old 10-13-2012, 09:05 PM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is online now
Yada Yada Yada
If you have a 327 to work with, supercharge it. You will have a ton of torque.
A low compression street roots supercharged 327 is very basic easy to build and will GLH.
Eats all 383's and most 400's.
You have the right car for it and will really like the result. Easy 500hp+
Use these off the shelf L2441F30 pistons with a 5.8" rod , stock 327 crank and your 64cc heads on a stock deck height block.
(just shave the block enough to get straight decks. .005")
This gets you the right compression ratio ...
Use a Crane F278-2 #113841 cam 750-850 carb and a Weiand 142-177 blower.
2.10 to 2.33:1 drive ratio.
