optmia battery going dead - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-20-2010, 07:33 PM
watchdude1's Avatar
HI, can you use a battery tender on an Optima Battery?
I have an battery tender on my 1930 coupe I plug the battery tender in and left it on for 4 days, then went to start the car today and the battery was dead it is 1 and a half years old and I have a battery disconnect I click off when I dont use the car.so it should not have anything too do with instrument draw.I heard you can't charge Optima Batteries is this true?
The car started fine until I used the tender. I am going to use a regular 6amp charger and see what happens.
Old 03-21-2010, 08:14 AM
302 Z28's Avatar
I am on my 3rd Optima battery. The first 2 were replaced under warranty. So far this one seems to be holding up well. I also use a Battery Tender when not using the rod. I however use the Battery Tender Jr. IMHO Optima batteries are vastly over rated, along with B.F. Goodrich tires, K&N air filters the list goes on and on.
Vince
Old 03-21-2010, 08:29 AM
T-bucket23's Avatar
Wiki Edits: 26
I agree, pitch the Optima and get a good quality battery of the proper rating for your setup. Everyone I know has has problems with the Optimas.
I would look for an Exide, in my opinion they make the best batteries. Napa batteries are re-labeled Exides
Chet
Old 03-21-2010, 10:06 AM
Wiki Edits: 31
other thing that many people do is use yellow tops.. those are deep cycles and are not designed for continuous use..
I'm not an Optima advocate. only time 1 would really be required IMO, is when the battery is in the passanger compartment.. but otherwise there a fancy cool looking battery, but a lead acid battery would do the same thing at 1/4 of the price
Old 03-22-2010, 06:53 AM
Vendor
Hi watchdude1, I’m sorry to hear about the problems you’ve been having with your battery and I’d like to help. Can you tell me what the voltage reading is on your battery? Can you describe the battery disconnect device you are using or post a picture of it? Most battery chargers work just fine on Optima batteries, although chargers with “gel” or “gel/AGM” settings should be avoided. This video offers some general tips on proper battery storage- http://www.youtube.com/watch?v=Z40SQCKWKNw
Jim McIlvaine
eCare Manager, OPTIMA Batteries, Inc.
www.****************
Moderators note: Check business posting guidelines here
Last edited by 302 Z28; 03-22-2010 at 07:37 PM. Reason: Violation of guidelines. Please see: general board guidelines.
Old 03-22-2010, 10:17 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
i like Optima red top batterys.. the unit I bought in 2001 is still operational
I have 3 Optima batterys in use now. Obviously some folks mileage may vary.
I have lead acid battrys from WalMart in my VW Jetta and lawn tractor. No problems with them in 2 yrs
Old 03-24-2010, 01:26 PM
ford 8n
I have a 1948 Ford 8n tractor that I want to replace the 6volt battery with a 8 volt battery to better start the tractor.I need help in knowing how to adjust the volts regulator or even if I need to adjust.
Old 03-24-2010, 05:17 PM
Rickracer's Avatar
ASE Master Tech, Fabricator
Last wiki edit: Taurus 2-speed fan control wiring diagram Last photo:
I've got a Red Top Optima in my boat that I SWEAR, no exaggeration, is at least 8 years old, and was in my black S10 when it burned down. It was mounted up under the bed just ahead of the back bumper. The handle was melted a little bit, but other than that, it looked OK. The truck was set on fire in my driveway, ( I think by one of my daughter's ex boyfriends, but never could prove anything), and I had to towed to my shop about a week later. After about a month sitting at the shop, I started taking the truck apart to salvage what I could, and sold the narrowed 9" rear, and nearly started another fire when the melted battery cable made contact with a ground. It's been my boat for at least 4 years now, and not been used, nor had a charger on it for almost 2 years now. About 2 or 3 months ago, I went out, hit the key and it spun right over like brand new. Needless to say, I now have Red Top Optimas in everything I own,
Old 03-24-2010, 06:05 PM
302 Z28's Avatar
Congrats, my 3rd red top seems to be holding it's own also, keeping my fingers crossed.
Vince
Old 03-25-2010, 08:37 PM
I have an Optima Battery in my Coupe that is 8 years old and still kicking. No tender, no nothing. It can sit for 3 months and still crank right up. The Optima in my truck is 6 years old and gets the same treatment as my coupe. (I rotate driving them). The one thing I know about Optima Batteries is they do not like a fast charge. 2 Amps for 24 hours is what you need. It has been a while since I read the fine print, but you need to read the charging instructions that come with the battery to get the good performance from them.
Trees
Old 03-25-2010, 08:57 PM
302 Z28's Avatar
That is probably what is saving my 3rd Optima, the Battery tender Jr. only puts out 750ma on float charge.
Vince
Roll Bar Install Advice Mustangsaly General Rodding Tech 12 12-02-2007 08:33 AM
battery keeps going dead, i need some f#*%&!g help 406 ss monte Engine 21 10-12-2006 03:43 PM
Need help please with an electrical headake bowtieorbust Electrical 15 01-26-2006 03:01 PM
i need some help. battery keeps going dead. 406 ss monte Electrical 1 05-31-2005 01:56 AM
1980 corvette battery keeps going dead? Aboveknee Electrical 5 01-23-2004 03:56 PM
