Orange peel
I am wanting to know if anyone has any suggestions as to how i can spray ppg concept dcu 2055 with out getting orange peel(or any clear for that matter). I have tried everyhting and am using a sata rp at 29-35 psi with wide fan and moderate amount of materials. I have adjusted this gun every which way and can not get it to lay down clear. Ready to go back to my devillis "war heroes" at least they work.
http://www.southernpolyurethanes.com...your%20gun.htm
Follow these instruction and you will soon be laying material wet and slick.. Sam
Thank you sam, I will try this. And for the other guy; I am sorry but a rp is not hvlp, thanks any way.
Dave,
Any time you buy a new gun you will need to go through the adjustment drill..One trick is to run about 100 psi at the wall and then adjust the air so you get about 25-35 psi at the cap and those guns like that a bit better, You may need to tweak it a bit to get the atomization right..then starting from completely closed open the fluid until the gun starts shooting and try that on a test panel..Then keep tweaking until you get there..once you have down then make a note of the settings for that gun so you can back to the right settings when you take the gun apart for cleaning.. Sam
are you using reducer, how much, what temperature, what size tip is it?
Yes, MitMaks I am using reducer. Always in accordance with weather temp. Since every car I do is a overall, I usually use high temp so i can "try" to get it to flow. I mix first coat according to directions, and add About 10-15 % more reducer on second coat. When using ppg dcu concept 2021 or 2055 it does not matter what or how i do it, it looks like rocker gaurd. Have accused my supplier of buying seconds, he did not like that. Have even showed him what i ca do with other clears such as Nason. I can lay down Nason 496-00 like glass, just wish it ways higher end like the dcu concept is supposed to be. If you can shoot me good advice like Sam has, have at it.
Im thinking this clear has more solids unlike Nason thus it needs more reducer. I personally always overreduce paint/clear to lay it out with HVLP, bumping up pressure helps out too.
Wow, I asked for advice and got it. I am going to spend plenty of time spraying test panels before spraying my current job. Thank you everyone for all of the advice. I will post again when I get results. Any other suggestions are welcome.
Thank you for all the help, clear coat is almost like glass. Turned up inlet psi, reduced material flow. Are there any better guns than sata, or how do they compare to the Iwata. What is a good gun, my partner is looking for one too?
just remember orange peel is almost always too much material . urethanes don't flow . shoot for effect . sounds like you got a handle on it.
| I always get orange peel! I hate orange peel! | shad9876 | Body - Exterior | 15 | 10-14-2008 08:45 AM |
| Base coat orange peel - what should I expect | cboy | Body - Exterior | 9 | 11-22-2007 07:51 PM |
| Orange Peel in clearcoat | duallybuster | Body - Exterior | 4 | 03-22-2006 08:53 PM |
| Removing Orange peel from matt/flat/satin/suede clear? cutting and buffing? | myfamiliacc | Body - Exterior | 3 | 04-11-2005 12:05 PM |
| Orange Peel After Sandblasting | Festive57 | Body - Exterior | 11 | 03-23-2005 07:22 PM |
