Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Orange Peel
Thread: Orange Peel
Old 05-23-2005, 02:44 PM
baddbob baddbob is offline
Borrow or rent a buffer, there are foam pads available for use on a DA and it will work if you set the DA on spin mode but a buffer works way better. Make absolutely sure that any tools that have been used with sandpaper are completely clean before using them for buffing- a small piece of abrasive from previous sanding duties can really ruin your day when buffing. Anything related to buffing and colorsanding must be kept perfectly clean.
