We're winning the case!
Hotrodders Bulletin Board > Tech Help > Body - Exterior
  #1
Old 09-29-2002, 07:15 PM
Coodeville Coodeville is offline
Post Orange Peel in Acrylic Enamel
What can I do about the orange peel in my acrylic enamel paint job? The paintwas applied in July of 2002.
Old 09-29-2002, 07:20 PM
Halloweenking's Avatar
Halloweenking Halloweenking is offline
Fantastically cannibalistic!
Post
wet sand and buff. Depending how bad it is start with a 400-2200+ then buff with the finishing/polishing compound by 3M and/or meguires No.7
HK
[ September 29, 2002: Message edited by: Halloweenking ]</p>
Old 10-02-2002, 08:17 AM
Joe S's Avatar
Joe S Joe S is offline
Post
You can make it look like glass with what Hollow said, go easy with the 400 it will sand quick, maybe start with 800 if not experianced.
Old 04-01-2003, 05:51 PM
Post
I wet sanded and I lost a lot of my gloss. I guess I should just reshoot it, correct? I've got a little bit more experience now. So this might not happen again. The last time around, I think I put too thin of a coat on the fender.
Old 04-01-2003, 06:31 PM
Post
Wet sanding will of course dull the finish. Once the area thats being wet sanded is uniformly dull, buff it out with a buffer and polishing compound like I said above.
HK
Old 04-01-2003, 09:54 PM
Post
As soon as the weather clears, I'll give it a shot.
Old 04-02-2003, 01:55 AM
senor_limpio's Avatar
senor_limpio senor_limpio is offline
The Dude
Post
It should look good after you buff it out. Had the same sort of problem with a car of mine once. After wet sanding, and buffing, it looked 100% better!
Seņor
Old 04-02-2003, 01:57 AM
The Dude
Post
Oh yeah, I almost forgot... if you are doing this outside on a sunny day, WEAR SUNSCREEN!
Got burned bad when I did mine years ago..
Seņor
Old 04-02-2003, 09:09 AM
55twodrpost 55twodrpost is offline
Post
i shoot a lot of acrylic enamel and if you decide to re-shoot it. when you get to your final coat and have a little paint left in the gun, mix in about a quarter of your guns cup full of thinner and spray a light even coat over the entire thing. the paint will lay down with almost no peel at all but don't do it to soon after your last coat or it will run like crazy.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
