Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - orange peel, long sorry!!
Old 07-29-2012, 05:31 PM
JCAR JCAR is offline
I know peel has been covered many times, and I am sorry for bringing it up again, but I am not sure what to do about my specific challenge. Long story short is, I laid the clear on the flat areas like the hood and roof just fine ( or at least good enough for me !!), but i peeled the vertical surfaces. I also had a couple "flow indicators" in the vertical surfaces. I am guessing air pressure too low? It's a pick up and I still have the bed to clear, using water- base base coat, not under any time constraints, and I don't want to make the same mistake. The peel is not real bad, I am sure it will cut and buff, but I must be doing something different on the vertical surfaces? Any help or suggestions are appreciated, thank you Jcar
