Order of dis-assembly - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-10-2011, 07:45 PM
I pulled the whole front end out from under my Buick Skylark with the intention of taking it all apart to clean, blast and paint and then rebush, including new ball joints.
Not sure what the proper dis-assembly order I should use with safety being parmount.
ID:	59609   Click image for larger version
ID:	59610   Click image for larger version
ID:	59611   Click image for larger version
ID:	59612   Click image for larger version
Old 11-11-2011, 12:31 PM
35terraplane's Avatar
Order of dis-assembley
I'm not sure that it matters, but ever thing you take off bag and tag, if you can. If you are going to take the a-arms apart, don't kill your self, there is a big spring in between them, and things will fly if you don't have it tied done good. Good luck.
Bob
Re-assembly order? BMM Body - Exterior 11 08-25-2008 10:35 PM
head assembly Q, more like dis-assembly bullheimer Engine 5 11-27-2007 04:48 AM
64 Merc cyclinder order/firing order 64merc Engine 1 07-11-2007 08:17 AM
Any particular order ? DrBee8457 Suspension - Brakes - Steering 4 05-10-2007 10:10 AM
350 rod order 1969NovaSS Engine 4 12-01-2005 10:17 PM
