Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Order of things
Thread: Order of things
Old 08-24-2005, 09:54 PM
BondoKing's Avatar
BondoKing BondoKing is offline
KING OF BONDO
Last journal entry: My little helper
Lets make it simple, if you are going to use todays products, you are going to use EPOXY, 2K PRIMER, POLYESTER PRIMER, BASE COAT, CLEAR COAT.
The epoxy is great for plastics, bumpers and bare metal, you can cover the epoxy with body filler for repairs.. You can then follow that with 2k to cover your repair area's... Then all you have left is bc/cc...
Too many people will not let go of something they have gotten used to or someone told them something that is not right, but they paint well.. etc....
The poly primer is like spreading metal glaze over a panel, except it is sprayable ( nice )...
For most repairs when you cover metal use epoxy. You dont have to go over it with 2k if everything is tip top.. You can let it flash and bc/cc.. For most they will cover with 2k to check bodywork etc...
Hope this helps some... It really is not as hard as many make it bro
BK
