Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Organization of Hotrodders Bulletin Board
Old 04-12-2007, 03:43 PM
grouch's Avatar
grouch grouch is offline
Last wiki edit: How to document your project
Last journal entry: 1949 Olds -- Rotisserie, pt. 9
Wiki Edits: 2
Aha! An opening for debate!
Originally Posted by powerrodsmike
having trouble sleeping, eh Grouch?
It's those [censored] state tax instructions with the logic of a legislature: Tip -- For the first person (yourself) listed on the return, use SSN boxes labeled B to enter your SSN. For the second person (spouse) listed on the return, use SSN boxes labeled A to enter your spouse's SSN. B is first? A is second?
Ok i can simplify this so that even I can understand....
Make one big category. call it hotrodders.com.
WWW organization:
1. hotrodders.com
2. miscellaneous
That first box is a big one, so we need smaller boxes in it to break it down.
It will be easy for me. It'll be organized just like my shop.
Sooooo... you have [shop] and [everything else], at least. Does [milling machine] land in [shop] or [else.kitchen]? If it's in [shop], do you have [shop.carlift.milling machine] or does it land on [shop.floor]? The point being that even the most disorganized looking shop has some organization about it, even if it's not apparent to anyone but the shop user.
Nice job Grouch
Thanks. (Are you setting me up for a sucker punch?)
I think if the suspension forum had frame added or we added a frame/ structural engineering forum for all of those fabrication questions it would be good. ( to me 'frame" is the bare structure and "chassis" is the complete assembly of suspension and steering parts.
Just like Henry Highrise pointed out, a frame is a part of a chassis -- it is logically a subcategory of the major category.
My basic argument is that we have subcategories defined without the major categories to which they logically belong. Suspension - Brakes - Steering is one glaring example. Those are 3 subcategories of a chassis, but there is no chassis. On the other hand, we have 2 miscellaneous areas.
