Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Orientation of large splines on '95 GM pitman
Old 01-31-2013, 10:15 PM
Mutt's37Buick's Avatar
Mutt's37Buick Mutt's37Buick is offline
I'm trying to determine if I will be able to use the pitman arm that is from a 95 Roadmaster on a 77 bronco Saginaw steering box. I was told ford bronco pitman arm evidently has large splines at 3,6,9 & 12 oclock. I assume that means 6 & 12 are aligned with the pitman arm axis.
My question is:
Does anyone know it the splines on a 95 Roadmaster Saginaw pitman arm are aligned similarly? This would help because I would like to use 95 spindles.
Thanks
