Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Orientation of large splines on '95 GM pitman
Old 02-01-2013, 01:12 PM
aosborn's Avatar
aosborn aosborn is offline
Last wiki edit: Suspension: designs, shapes, sizes Last photo:
Wiki Edits: 7
If the pitman arm you intend to use fits the splines on the steering gear you don't have to be concerned wether or not it has the proper master splines. You can remove a spline on the pitman arm wherever you need to when aligning it on the steering gear. When doing something like this, you need to be certain that the pitman arm and the idler arm are the same length so the steering linkage will work properly. The spindles are another matter altogether...
Andy
