Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Orientation of large splines on '95 GM pitman
Old 02-01-2013, 03:04 PM
Mutt's37Buick's Avatar
Mutt's37Buick Mutt's37Buick is offline
Thanks for your help.
I will be using the pitman arm, idler, and front spindles all from a 95 Roadmaster. Did not have room for the 95 Roadmaster steering box because the chassis is very narrow at the front axle. That is why I'm planning on using the Bronco steer box mounted to the outside of the frame.
Thanks
