orig. radiator - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-07-2002, 09:59 AM
Post orig. radiator
is it worth keeping the orig. radiator out of my 1950 truck? I'm wondering if it will cool well enough to cool an engine running up to 500 HP, or what the limitations of it would be.
Old 02-07-2002, 11:05 AM
Cool
You can use the origonal radiator but you will most likely have to have it recored. I am using an origonal 57 Chevy 6cyl radiator in my car. It was a 2 row found at the swap meet. by itself it would most likely have worked for my 350. I had it flow tested and leak tested. It failed the leak test. So I had the man put in a 3 row. He said I will run cool no mater what. Some aditional things that will help keep your truck cool would include a fan shroud and a waterpump for a car with AC. They are more efficent and often help out. an aditional electric fan may be needed but is not normaly a must have item. Since truck radiators often have larger tanks you may be able to get a 4 row core. If this is true I would. It is only cheep insurance. My radiator man told me that a 2 row would work fine for my application but I wanted to be sure that it would work even if I added AC. And it only cost me an extra $35 bucks for the extra capacity.
Old 02-07-2002, 12:01 PM
Post
let me ask you another question, how do I tell the difference two row & three row etc.?
