Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - original 51 ford f1 speedumeter & cable /aod trans
Old 12-31-2012, 08:02 AM
LATECH's Avatar
LATECH LATECH is offline
If you have a U Pull it salvage yard nearby, you may find one from an early 80 full size ford or Pickup that will be the same as the photo.
If they still have anything that old laying around.
It should be a bunch cheaper, but you have to go out there, look around , find a possible car etc.
Then you still may need to order a different gear to make the speedo read correctly.
What gear ratio is the rear and what is the tire diameter?
Fact is stranger than Fiction
