-   -   original 51 ford f1 speedumeter & cable /aod trans (http://www.hotrodders.com/forum/original-51-ford-f1-speedumeter-cable-aod-trans-227720.html)
Buckeye Bob 12-29-2012 07:22 PM
:confused:I have a 51 ford f1 with the original speedometer & cable I have a
302 with a aod trans --how do i make this setup work? I have never done anything like this before,I appreciate all the help that i can get, thanks
LATECH 12-30-2012 06:03 PM
1 Attachment(s)
Is your problem what to do with the speedo cable?
Is this the part your looking for?
It will accept a speedo cable and fits an AOD
Buckeye Bob 12-31-2012 06:10 AM
Thanks,where do i get that part & do you have any idea of the price? Bob
LATECH 12-31-2012 06:58 AM
http://www.transmisioncenter.com
Look in the AOD section then go to the mustang retrofit section.
I think its like 40 bucks.
LATECH 12-31-2012 07:02 AM
If you have a U Pull it salvage yard nearby, you may find one from an early 80 full size ford or Pickup that will be the same as the photo.
If they still have anything that old laying around.
It should be a bunch cheaper, but you have to go out there, look around , find a possible car etc.
Then you still may need to order a different gear to make the speedo read correctly.
What gear ratio is the rear and what is the tire diameter?
poncho62 12-31-2012 07:55 AM
I screwed my original 51 F1 cable to a Turbo350, so I imagine they are mostly the same fittings.......Accurate, it aint, but thats another subject...lol
