original 51 ford f1 speedumeter & cable /aod trans - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-29-2012, 08:22 PM
Buckeye Bob's Avatar
I have a 51 ford f1 with the original speedometer & cable I have a
302 with a aod trans --how do i make this setup work? I have never done anything like this before,I appreciate all the help that i can get, thanks
Old 12-30-2012, 07:03 PM
LATECH's Avatar
Is your problem what to do with the speedo cable?
Is this the part your looking for?
It will accept a speedo cable and fits an AOD
Fact is stranger than Fiction
Old 12-31-2012, 07:10 AM
Thanks,where do i get that part & do you have any idea of the price? Bob
Old 12-31-2012, 07:58 AM
LATECH's Avatar
http://www.transmisioncenter.com
Look in the AOD section then go to the mustang retrofit section.
I think its like 40 bucks.
Old 12-31-2012, 08:02 AM
LATECH's Avatar
If you have a U Pull it salvage yard nearby, you may find one from an early 80 full size ford or Pickup that will be the same as the photo.
If they still have anything that old laying around.
It should be a bunch cheaper, but you have to go out there, look around , find a possible car etc.
Then you still may need to order a different gear to make the speedo read correctly.
What gear ratio is the rear and what is the tire diameter?
Old 12-31-2012, 08:55 AM
poncho62's Avatar
Wiki Edits: 5
I screwed my original 51 F1 cable to a Turbo350, so I imagine they are mostly the same fittings.......Accurate, it aint, but thats another subject...lol
Ford AOD trans...trying to gather some information Toddclary Transmission - Rearend 2 05-23-2008 09:47 AM
WTH does the TV cable connect on a Ford AOD? FrankR Transmission - Rearend 6 11-02-2006 02:19 PM
throttle & trans cable brackets Don Meyer General Rodding Tech 4 03-26-2006 10:39 AM
5.0 EFI & AOD INTO 55 FORD WAGON FORD 2DR Engine 8 03-25-2006 09:17 PM
MOPAR 440/ H/O & 727 trans 24,000 original miles fastco Engine 1 09-14-2002 05:23 PM
