Original Cam SPecs for a 77' 350 K10 truck
My Father in law needs head gaskets in his 77' 350 farm truck, I have an edelbrock performer intake that is sitting, so thats going on it and because I have nothing better to do in my spare time as a mechanic I am looking at the generic Performance cam 420. 442. lift. to throw. DOn't ask why I am doing it I just feel like it.
Is it worth it performance wise the cam new costs me 62.00 dollars, and I have lifters just sitting to go in so the extra 6.23 for a felpro cover gasket has me wanting to do it. What I want to know is roughly what was stock lift on a 4 bolt truck motor just to compare lift to lift? Thanks |
In that timeframe the stock 350 in a truck was only rated at about 160 HP, and the stock cam was very conservative. I've seen the specs a couple of times, and I think duration was about 185 at .050. The "hot" cam of that era was the GM 929 cam, and even that was only 195/202 at .050.
You can probably go up to about 204/214 (like the Edelbrock 1102) without losing the low end torque you need (heavy truck). Anything beyond that is probably not worth it unless want to do other mods. Bruce |
thanks guys, I figured the truck was under a .400
this is the spec I am going to use ro-2000 Perf. Cam; Hyd., (050) Duration at .050 Lobe Lift, 214 Exh., 204 Int., 112 Degrees Lobe Separation, 0.443" Exh. Valve Lift, 0.42" Int. Valve Lift |
| 390 truck engine specs | 72fordlb | Engine | 2 | 06-14-2009 12:21 AM |
| 79 Chevy Truck paint what was original? | cyclopsblown34 | Body - Exterior | 2 | 10-23-2007 10:59 AM |
| Original Sbc Torker Intake.. Rpm Specs Wanted | boneyard Buick | Engine | 1 | 03-20-2006 12:58 AM |
| ???about original specs on a holly carb jetting??? | Robbie | Engine | 5 | 04-02-2004 08:18 PM |
| 40 Ford truck chassis specs | New2theart | Suspension - Brakes - Steering | 2 | 01-19-2003 09:33 PM |
