original vavle cover clearance? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-22-2009, 07:07 PM
Hey guys, I'm wondering if anybody knows if i was to use the old original chevy valve covers ( the ones that had the cursive chevrolet stamped in them ), would there be enough clearance for my 1.6:1 rockers. I don't know if it makes a difference but I've got AFR heads too.
anybody see any problems with planning on doing this?
Old 03-22-2009, 07:54 PM
DoubleVision's Avatar
I don`t think you`ll have any problems. But if in doubt, you can get the extra thick valve cover gaskets made of cork that eliminate this problem. Just make sure you coat the gaskets in vaseline, this assures they don`t dry up, get brittle and form a leak. I have a set of the script valve covers, I love those, I just haven`t found a way to go about using them yet. I did figure out how to run a PCV system with them though as I knew if there is no ventalation it`ll push all the gaskets out and cause havoc.
Old 03-22-2009, 07:58 PM
I forgot about the pcv valve, were u saying you came up with a way to vent it? how?
Old 03-22-2009, 08:08 PM
What I did was find a older Edelbrock streetmaster intake that had the provision for a oil filler tube in the front of the intake. Corvettes in the 60`s used this tube with a PCV that screwed into the tube. All you have to do is run the PCV to the tube and use a screw on vent on the top of the tube to assure it gets fresh air. You can still order this tube and PCV system from any site that carries parts to restore classic vettes.
SBC front timing cover install question v8hed Engine 5 07-26-2008 12:04 AM
Advice on sealing new timing cover eric32 Engine 18 06-24-2008 06:39 PM
Help needed with new timing cover. eric32 Engine 8 06-09-2008 10:02 AM
roller rocker and valve cover clearance 56madmook Engine 5 03-24-2003 02:53 AM
How hard to do your own leather seats? stonedchihuahua Interior 16 12-17-2002 03:59 PM
