Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Ospho and Cold Galv
Old 12-02-2011, 07:03 AM
deadbodyman's Avatar
deadbodyman deadbodyman is offline
Wiki Edits: 11
I use Ospho but epoxy primer seams to work best to seal it all up...Have you tried using an epoxy? I'd have to say it sounds like your not getting all the rust out ,use the Ospho to remove rust NOT convert it...Some stiff wire wheels will help a lot..or a recirculating spot blaster...You are taking the glass out , right??????
