Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Ospho and Cold Galv
Old 12-12-2011, 01:32 PM
CADI70's Avatar
CADI70 CADI70 is offline
I hit it with a wire wheel and put one coat of Ospho on. Keep in mind some of the areas showing filler are fiberglass backed and have no metal behind them. I'm trying not to dig too deep in these filled spots, not to take out the existing fiberglass backing. Next, I plan on hitting it with a Dremel with a cutoff wheel and conservatively, removing more metal around bad pits. Ideally I’d like to redo the metal but I don't have the equipment of the $ so I'll be working with this.
ID:	60714   Click image for larger version
ID:	60715   Click image for larger version
ID:	60716   Click image for larger version
ID:	60717   Click image for larger version
