Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - The Ospho Solution..(rust removal)
  #102 (permalink)
Old 07-18-2011, 02:44 PM
dixiedart dixiedart is offline
I will want to remove every friggin' trace of the stuff then, just to be sure but have yet to read exactly the best method. If someone could post the exact procedure it would be nice. I know DBM doesn't bother, only 180's and W&G remover then sprays. SPI site really doesn't give a step by step (obviously). I only use the stuff after a good 80 grit sanding, metal is clean, and then a fine wipe down with ospho towel in one hand and wet towel in the other, very little is used and laid on light, but does the trick. All panels will sit for days or weeks before I'm ready to shoot epoxy. I feel a red scotchbrite and garden hose would obviously do it - but it'll flash rust instantly here so ......
Name:	P1080868 (Small).JPG
