The Ospho Solution..(rust removal) - Page 10 - Hot Rod Forum : Hotrodders Bulletin Board
Closed Thread
  #136 (permalink)
Old 05-22-2012, 11:44 PM
Malibulvr's Avatar
Hey Mike, do you have new links for your videos, they seem to be dead?
Quick reply to this message
  #137 (permalink)
Old 05-23-2012, 12:13 PM
boatbob2
ospho....
hi,on that matador,Ospho would work great, using a spray bottle,spray the entire top,(in the shade if possible) walk away,wait a couple of hours,top should be black,or a white powder in places,re-spray it,go back next day,spray small areas,and while wet,i use a 3m gray pad,and sand small sections,after top is completely sanded,,wash with soap and water,dry GOOD,(very good)use grease and wax remover,then spray your 2K primer.then go on to the next section.
  #138 (permalink)
Old 05-23-2012, 02:54 PM
123pugsy's Avatar
"Thread Cop"
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
Just like to add, after doing all this I still had powder that didn't come off. I used a wire wheel in a drill and got a lot more powder off that didn't appear to be there.
  #139 (permalink)
Old 05-23-2012, 05:42 PM
If you want to remove it you have to rinse it while it is wet and active. If you have to rewet, then it takes a few minutes to get active with the dry stuff already on there.
  #140 (permalink)
Old 05-24-2012, 05:59 AM
deadbodyman's Avatar
Wiki Edits: 11
I'll have to try something different I down loaded them on streetfire.net and they keep getting deleted...I'll work on that..any suggestions???? I have a few more rust vidios to add also...
  #141 (permalink)
Old 05-24-2012, 07:40 AM
cyclopsblown34's Avatar
Colorsanding painter
Too bad streetfire is blocked from work. Can you load to Youtube?
  #142 (permalink)
Old 05-24-2012, 07:46 AM
boatbob2
rust removal.....
Hi,after the ospho dries,when im ready to prime,that white powder is present,usually not all over,but in blotches. i re-wet USING OSPHO,then using a 3-M grey pad,i sand the snot out of it.wash the part,with soap and water,DRY GOOD (to prevent flash rust) i usually put the part in the north Florida sun,to let the dampness evaporate, then prime using a 2K primer. i just finished 2 panels,that were very rusty,surface rust,with some deep rust (not rust thru) i did the rust removal as i said,and primed them,you would NOT believe how nice those panels came out.ive tried a bunch of different ways,to remove rust,with OSPHO ive never looked back,(wish i owned stock in the OSPHO company)....
  #143 (permalink)
Old 05-24-2012, 04:48 PM
Wiki Edits: 11
Sure ,I dont see why not..Thats where I should go then????
Puggs, I'm not sure how you started or anything but after sanding with 80 grit its very important to get all the contaminets off with afew applications of wax& grease remover sopping wet rags.Ospho wont remove oils and other contaminets..then scubb it in good with a scuff pad for clean metal and light surface rust,The heaver the rust the more agressive wire wheels you need and you'll need die grinders , side grinders and big 5"cups for pitted stuff a drills rpm is way to slow to be of much use. have you had any other problems after you got the powder off???? BTW,what I think happend was sometimes in high humidity it'll turn to a powder but its usually greenish...A second coat will remove it back to shinny clean something esle that might have caused the white powder would be not wiping enough off before it started drying...
Theres always some powder when I sand it ,it is a coating after all..
I wish you Pm'd me when you used it,A ton of people do I'll even give you a number to call for help...This is an important first step and it needs to be done right I'd hate to see anyone have any problems.....
  #144 (permalink)
Old 05-24-2012, 04:54 PM
Wiki Edits: 11
I wish I had some stock too. you got any pics Bob???
  #145 (permalink)
Old 05-25-2012, 09:45 AM
Michel, Youtube is the one I can access. I used to have access to streetfire til we got a new netnanny here at work. At home, I don't have time to get on the interweb. I appreciate you sharing your knowledge with us all on here.
  #146 (permalink)
Old 05-25-2012, 10:31 AM
Wiki Edits: 11
You tube it is then...
  #147 (permalink)
Old 05-25-2012, 10:34 AM
Wiki Edits: 11
And some stock in SPI and Hand kind ,now theres my three favorites..
  #148 (permalink)
Old 05-28-2012, 04:26 PM
Last journal entry: getting started
Ok I'm lazy and don't want to read every thread...
What do I do with the areas (nooks and crannys) I can't reach with the sander or sand blaster? Can I soak or spray the areas with the ospho and never think about them again? I am almost ready to shoot the SPI, but painting inside frame rails, enclosed rocker panels and behind door jamb probably won't get paint! Any advice?
Thanks,
Jerry
  #149 (permalink)
Old 05-28-2012, 07:31 PM
boatbob2
nooks and crannies.......
Theres not much else you can do to the places you cant blast,i would OSPHO the crap out of those places,2 or 3 GOOD coats,THEN TRY to spray primer in there........
  #150 (permalink)
Old 05-28-2012, 07:50 PM
Wiki Edits: 11
Thanks,
Jerry
Jerry's right there isn't much you can do.what would do is (lets say a rocker or frame rail) is make a hole (the right size for an undercoat plug) and use a wand to spray the ospho in there real good (drench it) Then using the wand blow air all though it kinda blowing it around everywhere in the nooks and crannys,and pushing all the to the other end where it can drain out...then do it all the other way,repeat blowing every 15min so none of the ospho collects in pools... blow it out maybe two more times (until it stops leaking out) and let it dry for a few days to a week ...prime with a wand then some rubberized undercoating ,I hear a lot of guys like bed liner....THEN walk away and never think twice about it ,you did all you can do and it'll probably still be around for the grand kids
Closed Thread
Muriatic Acid Rust Removal 11echo General Rodding Tech 23 03-22-2015 09:48 AM
secrets of surface rust removal revealed Randy Ferguson Body - Exterior 178 09-24-2011 09:36 AM
Rust Removal Tips Riot Racing Body - Exterior 13 10-14-2009 05:46 PM
Rust Dissolver versus Rust Convertor? 66GMC Body - Exterior 9 11-06-2005 05:48 PM
Rust removal trick(maybe?) oldred Body - Exterior 4 06-27-2005 01:16 PM
