The Ospho Solution..(rust removal) - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
Closed Thread
  #16 (permalink)
Old 04-02-2010, 08:01 PM
deadbodyman's Avatar
Wiki Edits: 11
Unexpected test results
Today the epoxy was cured .......To test it, I stuck my fingernail in it to see how hard it was, my nail couldn't catch hold so it was ready.
I started by putting a blob of bondo on unsanded epoxy primer and stuck two pieces of 3-M duct tape on the hood.
I pulled the tape of quickly and the primer stayed.showing some pretty good adhesion of the primer to the Ospho treated metal.
Then I got my three point putty knife placed it at the base of the blob of bondo and whacked it with a hammer...to my surprise the bondo split leaving a small amount still on the hood.
Then I tried scraping it off,some more came off but I had to sand the rest to get it all off.
After I sanded the bondo off I stopped so you could see the primer still there.
If you look close, after I sand the bondo off you can see the Ospho coating still there ,it looks like an e-coat at the edge of the shinny sanded metai theres a grayish ring just before the black primer.http://www.streetfire.net/video/osph...er_1472412.htm .
I always sand the primer before I start applying the bondo.I really thought the bondo would come clean off the primer but as you can see bondo sticks to unsanded primer extremely well.I was surprised and impressed to say the least.
I'll still sand before filling but its not really necessary.
I primed the other side of the hood after all this ,and We'll test the untreated side as well, but as far as primer having adhesion problems with Ospho ,Clearly you can see its not an issue when done properly.
I'll entertain any other thoughts on tests anyone would like done if there are any other ideas.
Next,I will be treating some seriously rusted ,pitted steel on that fury roof.
Quick reply to this message
  #17 (permalink)
Old 04-04-2010, 06:22 AM
Wiki Edits: 11
Sparky,
There are many ways to get a job done. As a young apprentice I was taught this method by an old timer. I've been using it ever since (over 25 yrs).I've always worked in shops that restored all kinds of autos and built drag cars,(Even met "Big Daddy" a couple times) ..
The man that taught me this ,worked at restoring rare, high dollar, cars for museums for years.
Sometimes sandblasting is NOT an option,mostly because of the mess ,the abrasives get everywhere ,in every nook and canny in the shop even with a booth its still gets spread around the shop.
Most body shops I've ever worked at don't do blasting at the shop and send that work out....That's what I would suggest doing if anyone has there heart set on media blasting,unfortunately, its expensive and requires a pro to properly strip a car and there's no guarantee it'll still be straight.(I prefer chemical stripping)
Then, when you get your car home you need to protect the bare metal right away with epoxy primer. Unfortunately,it takes time to properly prepare a car for primer.two to three times longer for a DIY... I
t doesn't matter what method you use to strip your car, Ospho will protect bare metal from surface rust for many, many months, I always apply the Ospho IMMEDIATELY after exposing the metal.Its been suggested and agreed upon that getting the epoxy on immediately is the proper way to go and no one should trust a sandblaster to prime their car properly, its a completely different trade.
So, this is how I start a resto,chemical strip and Ospho,its another option to letting your car get all rusty or after paying a small fortune getting it blasted,Letting it sit and rust is going backwards.
Any body can apply Ospho to a complete car in LESS than an hour,(longer if if it has rust) and you'll be in no rush to prime for months.
Even if it has no rust at all, it can still be used.This is the main advantage of using Ospho but there are a few more.As far as I can tell, nobody questions it's ability to remove rust or etch metal,the problems start with getting primer to stick to it, that's never been a problem for me ,so I decided to show how I do it and how easy it is to apply and then do a few adhesion tests to show, when properly done its not an issue.BUT...if anyone is a little leary ,you can always sand it off one panel at a time and work that panel ,prime and move on to the next. Always epoxy prime before doing any body work ,Bondo will not stick to Ospho....Also,if anyone has used Ospho and had problems this would be the place to ask about it and find out why.Its one of my favorite products and should work well for anybody.
This is simply my attempt to end all the misconceptions caused by misuse of a good product,by someone that uses it..... I'd do the same with ANY of my favorite products,if the use of them were to be disputed......One of the popular questions in the forums is ("My car has been blasted and its rusting,What can I do") ....
I'd like to add that in most cases, everyones opinion is welcome but in this case all the opinions have only added to the confusion so this is my attempt to back up my opinion with facts and end the confusion....any advice on how to better accomplish this would be welcome and recieved in the sprit it was intended........Thank You.........
.Mike O.
  #18 (permalink)
Old 04-08-2010, 07:12 PM
Wiki Edits: 11
Today ,after letting my old hood sit for another week,I did all of the same tests to the other(untreated) side plus redid the bondo blob again.
I added another test used by the military that another member told me about....
page 54 on this link is instructions for how to do a cross hatch cut adhesion test...
https://www.oskgpsc.net/otc/paintspec.pdf
(a shortcut direct to the page is back space/blank out the pdf page number window at the top and type in "54" and hit enter on your computer)
...This test involved scratching lines through the primer all the way down to the metal,making nine squares.
I did this to both sides of the hood...Remember,one side was treated with Ospho and the other side was just sanded with 80gt da.Then both sides were cleaned with wax & grease remover and primed with epoxy.
I was told that masking tape would work fine for this test but I really wanted to put this to the test so I used duct tape again because it sticks way better than masking tape.Heres the pics of how I did it.
Name:	100_7050 (Medium).jpg
ID:	45021   Click image for larger version
Name:	100_7051 (Medium).jpg
ID:	45022   Click image for larger version
Name:	100_7052 (Medium).jpg
ID:	45023   Click image for larger version
Name:	100_7053 (Medium).jpg
  #19 (permalink)
Old 04-08-2010, 07:31 PM
Wiki Edits: 11
first I layed down two strips of tape over an untouched, primed surface and pulled them off,just like I did to the treated side a few days ago.
Then,I covered the nine squares with with two strips of duct tape and pulled them both at the same time. then chiesled off the bondo.Heres the video....http://www.streetfire.net/video/adhe...pe_1994959.htm
Again , I was very surprised at just how well the epoxy stuck to untreated metal..The SPI epoxy stuck every bit as well to untreated steel as it did to the treated steel I truly thought I was going to pull the primer right off the untreated steel.As far as I can tell, so far the ospho treated steel passed the adheasion tests with flying colors,and I'm even more impressed with SPI epoxy than I was before....and I loved it before...In a couple days I'll get started on that roof and show you just what this Ospho can really do with rusted metal.BTW if there are any more suggestions for more tests please let me know.
mike O.
  #20 (permalink)
Old 04-10-2010, 09:00 AM
DBM, is there any gaurantee ( you ) can make as to the life expectancy of a treated OSPHO Panel? Doing it your way , or if you did the work , how long can you gaurantee that rust will not prevail in the treated areas? Since you believe so STRONGLY in OSPHO, and if you were to do a customers car , can you warranty the treated Ospho area from rust appearing under the paint? Believe me i am watching this with great interest. I have some rust issues with my next project that i will have to attend to . I commend you for your strong dedication and determination to prove your respect for the product. My hat's off to you . A friend awile back had his 66 GTO painted and there was rust in the rear quarter panel, i dont know how the body man took care of it , but three years later , rust was forming under the paint. Regardless, i just want to know if this is a ( aslong as you own the car ) or if there is some sort of time frame here? I never used any of these acid products so i dont know ??????? Once again , i think what your doing is great , and it tells me more that whats written on the back of a can or bottle to actually see someone apply his knowledge and trust of a product set fourth in proof.
  #21 (permalink)
Old 04-10-2010, 10:17 AM
Wiki Edits: 11
CB,check the dates in post#39,LOL... the 1/4 as really been done for 5-6yrs unpainted just epoxy and its outside most of the time.not even the slightest sign of rust.
I guarantee my rust work for five yrs but it has to be brought in when it starts ...so far Ive never had one come back.
I've seen one car I restored for a friend in Fla. ,(a 69 camero) about twenty years ago and it looked like it was a year old paint job,but he took good care of it and keep it in the garage when he wasnt driving it..that makes a big difference.
The way I look at it ,On the east coast cars can rust within five yrs when new, so anything over that is great.
You got to remember with heavy pitted rust there isn't much metal left.the best thing is to replace it.(but that gets expensive) or clean up the rust (like my trim holes) and glue some metal to the back side for strength.
can you see the patch covering the holes from the inside? (the first pic below) I made the bottom of the 1/4 myself.It would have taken less time to replace the1/4with a good one but I couldn't find one plus the ones I found out west were to expensive I would have had to replace the whole body ,then I wouldn't want to make all the changes to the things I didn't like.Like the taillights and everything from them down.Working with metal is a lot of fun.I made the whole bottom 12" of the car by hand rockers and all.the roof was rotted with holes I repaired that with Ospho too its been two years now and still looks great but some day it'll start rusting again...it has to... its just the nature of metal to return back to its natural state.
But....I built this car with less than a 1,000.00 in cash and did most of it in my driveway... Dont ask how many hours .. I dont have a clue. I did it for fun.
Dont get me wrong Ospho wont solve all your rust problems.
any rust on the lower 12" of your car should be replaced with new metal but above that repairs will last a lot longer.
For example: if you have a rust hole at the front and back corners of your door ,chances are, the middle will rust out shortly to so dont waste time fixing that replace the whole door bottom.same with the rockers...
I guarantee no shop would fix my car at any price ,you have to enjoy this kind of work to do it.I wouldnt do this much work for anyone either.
I will admit I'm tired of working on this car and all I want to do is drive it now.I wont be painting it until next year...
Then ,I'll give it to my son........Maybe ,at least thats been the plan all along.....
Name:	100_6611 (Small).jpg
ID:	45055   Click image for larger version
Name:	100_5244 (Small).jpg
ID:	45056   Click image for larger version
Name:	100_5245 (Small).jpg
ID:	45057   Click image for larger version
Name:	100_5246 (Small).jpg
ID:	45058   Click image for larger version
Name:	100_5247 (Small).jpg
The Following User Says Thank You to deadbodyman For This Useful Post:
Metalman Sr. (07-25-2013)
  #22 (permalink)
Old 04-10-2010, 01:16 PM
Originally Posted by BarryK
A while back in the other threads I posted what the acid film will do to three different chemicals, related to just three different products,
OK, let's say I've inherited a project previously Ospho treated. What can be done to neutralize it before priming? Replacing a car isn't an option, there has to be something that will kill the acid.
  #23 (permalink)
Old 04-11-2010, 08:22 AM
shine's Avatar
SPI Thug
Last journal entry: some progress
reapply and rinse well.
  #24 (permalink)
Old 04-11-2010, 10:08 AM
"Replacing a car isn't an option, there has to be something that will kill the acid."
Free oxygen in the atmosphere will neutralize the acid. You could:
re-apply with Ospho
first rinse with 'sudsy' ammonia and water to neutralize
second rinse with clear water until clean
dry well
heat the panels above room temperature
prime
moisture condenses on sheet metal exactly the same way as an iced-tea glass and autobody products are petroleum based, they float on water. You really do need the get the moisture out of the pores of the metal if you want the job to last.
  #25 (permalink)
Old 04-11-2010, 11:07 AM
Old Fool's Avatar
IF that was me, I would wash twice with Purple Power with a pressure washer and give a good hot water pressure water rise after each washing.
  #26 (permalink)
Old 04-11-2010, 01:36 PM
shine's Avatar
SPI Thug
you need to reactivate it first then rinse.
  #27 (permalink)
Old 04-12-2010, 08:55 AM
GUYS...
please!!!
either send dbm a pm with your question for now or wait to ask till after the next final series is posted...
what has been presented is only a "introduction" paragraph worth of knowledge....
(how to acid scrub surface rust off a new piece of sheet steel in the first series)
the next series will be much more informative and more correctly done to judge from!!!
dbm has been submitting "first take" "raw" videos so I for one have been trying to help in the background to make the next one better....
(ex: it's my fault he didn't do the cut lift test correct at all on the second series test,,, my instructions weren't clear enough)
I have asked him to prepare a summary statement post,,,that should answer many/most of the common questions....
PS: "thank you" to whoever recently cleaned up the thread
  #28 (permalink)
Old 04-14-2010, 04:01 PM
Jon's Avatar
Jon Jon is offline
Hotrodders.com Administrator
Wiki Edits: 7314
deadbodyman -- can we publish this in the wiki? We can include photos, vids, text, etc. We can link it up with the Phosphoric acid as metal pretreatment article. I would like to have all sides of the Ospho debate properly represented in the wiki.
  #29 (permalink)
Old 04-14-2010, 04:35 PM
Wiki Edits: 11
Of coarse Jon, do anything you like. change it, rearrange it, whatever you like and see fit.
I still have three sets of adhesion tests to do on the hood,plus the heavy rust removal with its own adhesion tests.
I've just been a little busy the last few days.
  #30 (permalink)
Old 06-02-2010, 02:15 AM
Jon's Avatar
Jon Jon is offline
Wiki Edits: 7314
Thanks again deadbodyman -- I've put together a wiki article on this topic. Here it is: Rust removal with Ospho.
Some notes:
--I'm not sure how or if to include your adhesion tests. However, I'm open to input on this issue; one option is to do a second article with adhesion tests, and link everything together.
--I've linked to the Phosphoric acid as metal pretreatment article within the Ospho article (that article now also includes a link to the Ospho article). There is also a "Criticism" section of the Ospho article that addresses the controversy at hand, and mentions the opposing viewpoint.
--Feel free to edit the article anytime: update, correct, fix, add pics and vids, etc. Anyone else should also feel free to do so. If you don't want to edit the Ospho-specific article, there is always the more general Phosphoric acid as metal pretreatment article. We also have a huge Rust article.
--Waiting on that heavy rust removal. I'm hoping you can save me some time and add it directly to the wiki.
Closed Thread
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Muriatic Acid Rust Removal 11echo General Rodding Tech 23 03-22-2015 09:48 AM
secrets of surface rust removal revealed Randy Ferguson Body - Exterior 178 09-24-2011 09:36 AM
Rust Removal Tips Riot Racing Body - Exterior 13 10-14-2009 05:46 PM
Rust Dissolver versus Rust Convertor? 66GMC Body - Exterior 9 11-06-2005 05:48 PM
Rust removal trick(maybe?) oldred Body - Exterior 4 06-27-2005 01:16 PM
