The Ospho Solution..(rust removal) - Page 23 - Hot Rod Forum : Hotrodders Bulletin Board
Closed Thread
  #331 (permalink)
Old 07-24-2013, 07:39 AM
Originally Posted by deadbodyman View Post
Brian, I know its a bit early to say but whats your first impression of the master rust remover???? I also ordered some last week to try...
Is it actually removing the rust and does it prevent surface rust, it sounds like it does...
It sure looks like it works better than Ospho..
This one view is pretty impressive, but I have to do a lot more before I have a good idea of what it can do. But check out that floor where it dripped! I hadn't even noticed this until when I posted the photo, but DAMN that is silver metal down there!
Quick reply to this message
  #332 (permalink)
Old 07-24-2013, 08:09 AM
123pugsy's Avatar
"Thread Cop"
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
Those drips do look impressive.
How about dripping some Ospho beside those and let it set until it dries? This would be a good test.
  #333 (permalink)
Old 07-24-2013, 01:33 PM
Last journal entry: C10
How about in a double wall configuration like in a metal head liner? Do you reccomend spraying in the cavity and flushing it out?
  #334 (permalink)
Old 07-24-2013, 02:27 PM
Ospho rust converter loses strength as it is used, so it may not be a fair test, if the masterseries rust remover is reusable over and over. If it is that type product you could leave a heavily rusted and pitted piece of metal submerged in it until all the rust is gone, even in the deepest pits.
  #335 (permalink)
Old 07-24-2013, 02:30 PM
I don't know, but that is one of the fears of these acids, they keep right on working!
  #336 (permalink)
Old 07-24-2013, 03:18 PM
There are several types of acids used for different purposes but phosphoric acid is rather mild for an acid, and I don't believe it will keep working after it dries. Hydrocloric acid used for tinning auto body solder could be another story. Just the fumes of that stuff will rust your most valued treasure.
  #337 (permalink)
Old 07-24-2013, 03:23 PM
Pats55's Avatar
By all means spray the cavities and if you like you can flush it. In a lot of cases we just let the prep dry on its own. I have never seen a problem with the acid attacking the final finish coat or the primer. This particular product only contains phosphoric acid. As for cavities the eeci [extreme elements corrosion inhibitor]or Inner panel protector was designed for areas like this. We can also spray the silver primer or another primer in hard-to-reach areas within a engine cleaning gun. The ECCI has been a secret for a while. It was developed for bridge work in between the plates, it's highly anti-corrosive and makes an excellent seam sealer. I'll start a separate thread on this topic later.
  #338 (permalink)
Old 07-24-2013, 04:00 PM
123pugsy's Avatar
"Thread Cop"
Wiki Edits: 29
A fair test is whatever works easiest is the one I want to use.
If the Master series is as you describe, I'll buy that. It's pretty simple really.
Hey Brian, can you do a test for us?
  #339 (permalink)
Old 07-24-2013, 04:57 PM
Heck yes I will be doing that.
The Following User Says Thank You to MARTINSR For This Useful Post:
123pugsy (07-24-2013)
  #340 (permalink)
Old 07-24-2013, 05:35 PM
Pats55's Avatar
Hey Brian could you please hurry up the suspense is killing me, shouldn't take more than 10 min. to do a test LOL
  #341 (permalink)
Old 07-24-2013, 05:53 PM
Hold your horses for goodness sakes!
  #342 (permalink)
Old 07-24-2013, 06:17 PM
Hey Brian, Are you done yet?........
  #343 (permalink)
Old 07-24-2013, 06:21 PM
I'm innocent Pugsy, honest, I don't know anything about the mastercoat series, notice the key word is (if).
  #344 (permalink)
Old 07-24-2013, 06:28 PM
I'd just like to say I was using this stuff before it was ever cool
  #345 (permalink)
Old 07-24-2013, 07:16 PM
123pugsy's Avatar
"Thread Cop"
Wiki Edits: 29
It will take until it dries I believe.
Brian, correct me if I'm wrong but aren't those silver patches the result from the next day after the acid dripped and dried up?
Closed Thread
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
Muriatic Acid Rust Removal 11echo General Rodding Tech 23 03-22-2015 09:48 AM
secrets of surface rust removal revealed Randy Ferguson Body - Exterior 178 09-24-2011 09:36 AM
Rust Removal Tips Riot Racing Body - Exterior 13 10-14-2009 05:46 PM
Rust Dissolver versus Rust Convertor? 66GMC Body - Exterior 9 11-06-2005 05:48 PM
Rust removal trick(maybe?) oldred Body - Exterior 4 06-27-2005 01:16 PM
