The Ospho Solution..(rust removal) - Page 30 - Hot Rod Forum : Hotrodders Bulletin Board
Closed Thread
  #436 (permalink)
Old 08-01-2013, 09:08 AM
The rust I am working with laughs at the wire wheel, the wire wheel "polishes" the rust, that is about it. I don't know what is so different, but it does next to no-thing.
Soooooo, last night I tried a number of different things experimenting on this roof. And believe me, there is a reason why I am doing it on the inside first, I AM leery about the acid BIG TIME as I have had a catastrophic failure in the past.
Here is what I did in five minutes (I timed it) with my speed blaster with close to zero "overspray" of media, cleaned it up in 24 seconds (or so ).
I used a paint stripper to see if there was something there in a small area right below where I blasted it, it did nothing. There wasn't so much as a hint of paint, no discoloration of the stripper, nothing. I then took my new grinder flapper disc and hit that area, yep,I could remove the rust with it but WAY too much heat if you ask me.
I then put the towel down soaked with the MS. I know I'm cheaping out with just a little paper towel but I did keep it wet.
After a half hour....you can see a clear line where the towel was.
I did another one..
And it gave a similar result. This was after scrubbing with the scuff pad and rewetting a few times.
And another..
And scrubbing....
I am open to different ways to solve this but I am looking forward to having the cab blasted and rolling it into the booth at work and epoxy priming it!
Quick reply to this message
  #437 (permalink)
Old 08-01-2013, 09:22 AM
Pats55's Avatar
Mastercoat metal prep is designed to remove light to moderate surface rust quickly and leave a zinc phosphate film to prevent flash rust until the car is ready for primer and paint which could be a matter of months. Mastercoat Rust Remover /Descaler is much heavier stuff for moderate to heavy rust. As I said earlier I spent 20 years at shows every other weekend, telephones seven days a week and I can tell you from experience more bubbles are caused from not using metal prep than using prep. When you wire wheel rust off panel there still rust there and it will come back to bite you if you don't neutralize it with a prep.
  #438 (permalink)
Old 08-01-2013, 09:27 AM
shine's Avatar
SPI Thug
Last journal entry: some progress
speed blaster with the recover bag sucks. takes way too long. outside without the bag it would go faster . i had one for years that i used on jambs and places you just couldn't sand . one of the small siphon jobs would do it quick . if you decide to have it blasted brian be sure they do not use sand of any kind. it promotes rust .
  #439 (permalink)
Old 08-01-2013, 09:36 AM
life is a temporary assignment
Well not always true... I built a truck in 1995 and today sitting outside under a roof top Still look's the same as it did when it came out the paint booth...So that isn't always true... Other then this truck being dirty,,, It can go straite to a show today,,, Every repair made to this truck was still as good as the day we built it..
  #440 (permalink)
Old 08-01-2013, 09:44 AM
Pats55's Avatar
Apparently you must do excellent work and have luck on your side.
  #441 (permalink)
Old 08-01-2013, 09:48 AM
Too Many Projects's Avatar
A few beater muscle cars
Last journal entry: continued
Brian, have you done any research on rust converters ?? They chemically change rust into an inert material that stops the rust process and is paintable. I have been doing this for several years on my projects with good success. From what I've seen of your rust issue, it's minar and would be done in 10 minutes with a converter. I'm not dismissing your dilligence or desire to be "rust free" but even blasting will leave small particles of rust in pits that WILL return over time. The converter eliminates that.
  #442 (permalink)
Old 08-01-2013, 09:50 AM
I wouldn't call it luck...I have way more bad luck then good luck..
Do it right the first time or don't do it at all is my way of thinking... Never had to use any acid to build a car.. And never plan on using it..
  #443 (permalink)
Old 08-01-2013, 10:25 AM
Pats55's Avatar
In 1996 what primer were you using and what state are you in?
  #444 (permalink)
Old 08-01-2013, 11:18 AM
Of course there are a lot of factors in why things rust, why they fail, and so on. Hell, I have all the sheetmetal to this truck out in the back yard. It was primed in lacquer primer and painted in lacquer paint back in 1979! It's been sitting in the back yard for 20 years un-covered and there isn't a single bubble or rust spot showing! The chrome grille, it's all rusted but I don't believe there is a single spot of rust other than along an edge or something where the primer and paint got thin. The moulding down the center of the hood has rusted through for some reason, but the rest of the hood looks good, just seriously faded lacquer paint.
For that matter, I have an old vintage gas pump out back that was sandblasted and primed in urethane "Tint Prime" from S-W 20 years ago, 20 years in the weather, again, not a spec of rust or failure showing other than the primer loosing color and turning to chalk.
When I strip the paint off am I going to find the metal all rusted, I sure as heck don't think so, if it was after all this time it certainly would be bubbling or something.
  #445 (permalink)
Old 08-01-2013, 12:10 PM
Pats55's Avatar
Climate has a lot to do with it. The older primers had components not available today. Move your truck to Webster Florida at the end of two years you probably wouldn't recognize it. I would put out displays with old pitted rust, that had not rerusted in years. I would leave them out overnight and be there be a new layer of rust the next morning. For me if all the major paint companies recommend metal prep,with all their experience ,and technical know-how, and research and development I'll go with their recommendations.
  #446 (permalink)
Old 08-01-2013, 12:12 PM
Like I said, a lot of factors.
  #447 (permalink)
Old 08-01-2013, 12:16 PM
shine's Avatar
SPI Thug
but when all the major paint companies recommend rinsing the acid off while wet you ignore that. there is nothing wrong with metal prep but to leave it to dry and paint over is not recommended by the major paint companies.
The Following User Says Thank You to shine For This Useful Post:
NEW INTERIORS (08-01-2013)
  #448 (permalink)
Old 08-01-2013, 12:34 PM
Pats55's Avatar
For the hundredth time follow the data sheet ,damp rag in one hand, dry rag in the other. In 30 years I never had a problem with metal prep. About 15 years side-by-side with Capt Lee in a booth that I don't remember any issues with metal prep or Rust away.
  #449 (permalink)
Old 08-01-2013, 01:06 PM
You must not know how things are in in LOUISIANA.. I don't have to put that truck in FL to test what I test.. By air here,, I can spit in the Gulf of Mexico.. I'm 55 miles north from all the salt water I need... So it's been well tested my friend... We used PPG back then and ALL body filler was done With RAGE...
As far as rust goes... We watch it happen within Hrs here..
You won't sell me any acid, So no need wasting your time trying..Have a good day..
  #450 (permalink)
Old 08-01-2013, 01:12 PM
Pats55's Avatar
Well if PPG worked so great why would you consider changing? Let's get one thing straight you and I'll never agree on anything as for selling you anything I don't sell stuff anymore the rest of family does. I couldn't care less if you use acid or not. Have a great day
Closed Thread
Muriatic Acid Rust Removal 11echo General Rodding Tech 23 03-22-2015 10:48 AM
secrets of surface rust removal revealed Randy Ferguson Body - Exterior 178 09-24-2011 10:36 AM
Rust Removal Tips Riot Racing Body - Exterior 13 10-14-2009 06:46 PM
Rust Dissolver versus Rust Convertor? 66GMC Body - Exterior 9 11-06-2005 06:48 PM
Rust removal trick(maybe?) oldred Body - Exterior 4 06-27-2005 02:16 PM
