Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Otherwise stock 305 with performance cam
Old 12-23-2011, 11:24 AM
whyholdback whyholdback is offline
Last journal entry: update
You guys are forgetting about the OD. I didn't bother figuring out the actual gear because the OP indicated a definite lack of interest.
Figuring 2.41 is close, because a 3.42:1 axle with the 700R-4s 0.70:1 OD gives 2.38:1
In which case, the correct speedometer gears are a 17-tooth drive gear, and a 44 tooth driven gear.
