Otherwise stock 305 with performance cam
1 Attachment(s)
I am running a '91 chev truck 305 with a 700R4 trans in my T-bucket. Having never used a performance cam before, I was very pleasantly surprised at the increased performance with the Erson E110024 streetfighter cam. It doesn't spin the tires as easily off idle, which is a good thing, but it really comes alive immediately. No bog, even with the tight torque converter, this thing really flies. Super Stock style burnout yesterday. Brake torqued it in drive and it upshifted to 2nd with the tires burning and the front tires sliding. When I left up on the brake it just stayed in 2nd and went on down the road with the tires smoking. Very impressive for a little 305. The on road performance is very similar to what I had with the 355 with a stock cam. It pulls strong all the way up to upshift at about 5200 rpm. And the street manners are still very nice. Very glad I did the cam change. Looks like the best of both worlds to me. And now with the lockup torque converter wired up to control manually, I expect some real good cruising mileage. Thanks again for the great advice. BTW. It was almost 65 here yesterday so it was a nice day for a drive in the bucket. Merry Christmas. Allan
What rear gears and rear tires?
Something is wrong. 700R-4, 3.08:1 and 295/50R15 should be 1900 RPM @ 70 MPH, and 1350 @ 50.
Is your torque converter locking up? Is your speedometer calibrated? It should be an 18 tooth drive gear, and a 42 tooth driven gear. |
Big Al, glad the cam change gave the results you were after. Did the cam give you a bit of "rump rump"? I remember that you were hoping for a bit of "idle music".
Big Ed |
Might be a 2.41 ratio:
w/26.7" diameter tires and 1560 RPM= 51.44 mph 2100 RPM= 69.24 mph |
You guys are forgetting about the OD. I didn't bother figuring out the actual gear because the OP indicated a definite lack of interest.
Figuring 2.41 is close, because a 3.42:1 axle with the 700R-4s 0.70:1 OD gives 2.38:1 In which case, the correct speedometer gears are a 17-tooth drive gear, and a 44 tooth driven gear. |
But I cannot remember a '58-'64 application that would have had a 2.41 ratio. That ratio wasn't used during '55-'57, 3.36 was as high as they got IIRC. I know it prolly doesn't matter that much one way or the other but I wonder if there was a 2.41 used from the factory during the "Hotchkiss" era. |
Last I knew you had a TH350C. :confused: Oh well.
From my notes- I don't know who to credit it to: "55-56 had 3.70 with a standard trans, 4.11 with the OD trans, and 3.55 with the auto trans. In 57 they went to 14 inch tires and then they used a 3.55 with a standard trans and 3.36 with the auto trans." |
| All times are GMT -6. The time now is 10:56 AM. |
