Otherwise stock 305 with performance cam
I am running a '91 chev truck 305 with a 700R4 trans in my T-bucket. Having never used a performance cam before, I was very pleasantly surprised at the increased performance with the Erson E110024 streetfighter cam. It doesn't spin the tires as easily off idle, which is a good thing, but it really comes alive immediately. No bog, even with the tight torque converter, this thing really flies. Super Stock style burnout yesterday. Brake torqued it in drive and it upshifted to 2nd with the tires burning and the front tires sliding. When I left up on the brake it just stayed in 2nd and went on down the road with the tires smoking. Very impressive for a little 305. The on road performance is very similar to what I had with the 355 with a stock cam. It pulls strong all the way up to upshift at about 5200 rpm. And the street manners are still very nice. Very glad I did the cam change. Looks like the best of both worlds to me. And now with the lockup torque converter wired up to control manually, I expect some real good cruising mileage. Thanks again for the great advice. BTW. It was almost 65 here yesterday so it was a nice day for a drive in the bucket. Merry Christmas. Allan
What rear gears and rear tires?
Something is wrong. 700R-4, 3.08:1 and 295/50R15 should be 1900 RPM @ 70 MPH, and 1350 @ 50.
Is your torque converter locking up? Is your speedometer calibrated? It should be an 18 tooth drive gear, and a 42 tooth driven gear. |
Might be a 2.41 ratio:
w/26.7" diameter tires and 1560 RPM= 51.44 mph 2100 RPM= 69.24 mph |
with those super stock style burnouts I'll have an idea what ratio to look for. Of course I would tear it down and do a tooth count to confirm, before I ordered any parts . Allan
Not quite the smooth as a Singer sewing machine sound that it had. I really don't think that I could have made a better choice as far as cams go. If I bring the car up to 40 mph and then let off the gas so that it switches into overdrive and then switch on the lockup clutch in the torque, the rpm drops way down to about 1100 or 1200. Then I set the cruise control. So I wouldn't want anything more radical. I was surprised to have that much vacuum loss though. Used to have almost 21 in hg, now is just a little over 15 in hg. Not a concern, just a little surprised. Allan
You guys are forgetting about the OD. I didn't bother figuring out the actual gear because the OP indicated a definite lack of interest.
Figuring 2.41 is close, because a 3.42:1 axle with the 700R-4s 0.70:1 OD gives 2.38:1 In which case, the correct speedometer gears are a 17-tooth drive gear, and a 44 tooth driven gear. |
But I cannot remember a '58-'64 application that would have had a 2.41 ratio. That ratio wasn't used during '55-'57, 3.36 was as high as they got IIRC. I know it prolly doesn't matter that much one way or the other but I wonder if there was a 2.41 used from the factory during the "Hotchkiss" era. |
. My bad . Yeah. it would be nice to know the actual ratio, because I am always asked that along with the other usual questions. IE: eng., trans., cam,. So considering that the tire height is 26" (just measured) and the engine runs about 2100 rpm @ 70 mph., what do you suppose my rear axle ratio is ? 3.42:1 ? BTW, I am running a 39 tooth driven gear against a 15 tooth drive gear (if I remember correctly) and the speedo still runs slow. Not really wanting to change speedo drive gears, as they are not cheap. But as I mentioned, the speedo is electronic and programmable, but is close enough for me. I know how much it is off, so I drive accordingly. I did program the speedo when I had the TH350, and if I remember right, you can't get it exact anyway. Did you know that as tires wear, distances from point A to point B increase ? I used to have to keep records of my mileage for tax purposes at my last job. I used to set my trip meter in my driveway and reset at the mine entrance. As tires wore down, the trip distance would change from 32.6 min with new tires to 33.1 with worn.
Last I knew you had a TH350C.
Oh well.From my notes- I don't know who to credit it to: "55-56 had 3.70 with a standard trans, 4.11 with the OD trans, and 3.55 with the auto trans. In 57 they went to 14 inch tires and then they used a 3.55 with a standard trans and 3.36 with the auto trans." |
| Adding performance to a stock 350 | 1972 El Camino | Hotrodding Basics | 21 | 11-18-2011 04:13 PM |
| Performance Heads add in Chevy Hi Performance | sdimpala64 | Engine | 1 | 04-29-2008 08:59 AM |
| Debating stock vs performance cam bearings | CNC BLOCKS NE | Engine | 46 | 03-18-2008 11:03 AM |
| How much does a stock 55 chevy stock 1955 chevy weigh | tiresmoke55 | Body - Exterior | 4 | 08-24-2007 11:57 AM |
| extracting power form a stock 318 stock cam | satelite413 | Introduce Yourself | 1 | 02-03-2005 11:28 PM |
