out of 1st too soon. - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-23-2005, 05:59 PM
New Member
I have a C4 transmission, and the thing shifts out of first gear way too soon. Right when you take off it shifts with a little throttle, with a lot it feels like it keeps wanting to shift and does, still way too soon. Second to third shift is just about unnoticeable. It reminds me of a chev tranny with the tv cable removed or something. Anyone know what could cause this? I don't have the kickdown cable hooked up, but that's just for passing gear correct? Or does it hold pressure similar to a tv cable? I thought the modulator valve controlled the shifting, but that is new.
Old 05-23-2005, 06:19 PM
poncho62's Avatar
Wiki Edits: 5
I think that the kickdown linkage has to be hooked up for it to shift properly.
Old 05-23-2005, 07:59 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
if the modulator is new, I wonder if the 'pin' was not re-installed?
There is a round metal pin between the valve and the vacuum modulator.
If the pin is there..... check inside the hose barb of the modulator where the vacuum hose plugs on. IF there is a blade type screw there.... thread it in 2 full turns and test drive.
A pin .040 - .060 longer than the OE pin length will provide later / slightly firmer shifts tooo
Old 05-23-2005, 09:23 PM
New Member
i put the old pin back in...it just sits in the modulator on the side that goes into the tranny correct? I'll try adjusting it I guess. Where can I get this longer pin?
Old 05-25-2005, 07:55 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
you make a longer pin from a welding rod or some simular material
th350, no 1st gear!! judis951 Transmission - Rearend 19 03-17-2007 08:41 PM
Guys I sold my 1st Ford GT, The 1st for the Dealer Ford SVT Hotrodders' Lounge 31 03-22-2005 09:36 AM
SCCA CAN AM TRANS AM Series 1st Gen Camaros texasrat Hotrodders' Lounge 6 10-01-2004 05:24 PM
th350 1st gear manual shift problem desman Transmission - Rearend 6 02-08-2004 03:15 PM
