In and out the window - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-27-2003, 02:43 PM
Smile In and out the window
Okay, here is a really embarrasing question. I just bought a 31 A coupe.The front windshield is cracked and I need to get a replacement. This should be easy, if I just taje off the frame and take the whole thing to the glass shop-BUT
how does the frame come off? I can see the swing arms and wing nut, but there is obviously some sort of hing at the top, under the visor.Any help will be greatfully accepted. There will be a lot more questions, too.
Old 04-27-2003, 09:24 PM
Post
It's easy but not..... After disconnecting the swing arms you should be able to tip the windshield frame up and out and slide it off the hinge. The A hinge is just a curl on the body mating with a curl on the frame.
