Outer cam bearing - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-23-2010, 04:38 PM
Outer cam bearing
I just nicked my outer cam bearing pretty good when removing the cam out of my small block chevy. I'm assuming I can do it in the car since it is right there. DO I need a special tool to install this one or can I sink it like I would a normal bearing race??
Old 05-23-2010, 05:05 PM
GMC boogie's Avatar
Chances are you will never get the new one installed square without a cam bearing installation tool. The front cam bearing needs to be installed from the back side to do this.
How deep is the nick? It would have to be pretty deep and all the way across for me to change it.
Old 05-23-2010, 05:15 PM
The distributor gear put some scratches in it when I was trying to get it out. They're not that deep and do not go all the way across it, just a couple nicks here and there. I was wondering if it was bad enough to replace or if I should try to smooth it out with something and just leave it alone...
Old 05-23-2010, 05:33 PM
stoney 81ta's Avatar
I happened to do the same thing on mine its on the first bearing when you install the cam,dont mean to jump on your thread but i will be watching thhis for the replies.
Old 05-23-2010, 05:52 PM
GMC boogie's Avatar
It does not sound bad at all. The material is soft. I would reinstall the cam and spin it a few times,take it back out and give it a look.
From what you describe,I think you will be ok.
Old 05-23-2010, 06:04 PM
Should I hit it with some emery cloth or fine sand paper to make everything smooth??
Old 05-23-2010, 06:29 PM
GMC boogie's Avatar
I would just let the cam smooth it out. Using any kind of abrasive is just going to embed particals in the bearing...not good
Old 05-23-2010, 06:47 PM
techinspector1's Avatar
Wiki Edits: 326
I've encountered this before. I suspect all of us have dinged a cam bearing or two at one time or another. I have used a rough cut rat-tail file to cut down anything that sits above the plane of the bearing surface and wiped out the filings with my finger. Do this V-E-R-Y slowly and V-E-R-Y carefully and you should be fine. It ain't rocket surgery!
Old 05-23-2010, 07:32 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
I'm guilty also . It don't sound to bad from what you have described,
Rub your finger around the scratch feel how bad it really is probably can't feel to much like said before you can run the cam back in and turn it a few times Because it it a soft part or do what Tech said with the file but like he said be very careful and slow with the process. either way it should be fine. JMO
Cole
Would this Isky Hydraullic roller cam work good for my combo eric32 Engine 9 06-18-2009 04:36 PM
Roller Cam Thust bearing boobert Engine 4 04-04-2009 02:47 PM
cam bearing question eatonde Engine 2 02-01-2009 06:33 PM
Cam Bearing Question.. johnnya Engine 9 06-06-2006 07:33 PM
Spindle interchanges bskaggs Suspension - Brakes - Steering 11 06-05-2006 01:29 PM
