Outer dimensions of LT1? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-09-2012, 10:47 AM
Mutt's37Buick's Avatar
I'm looking for a 3d CAD (computer aided drawing) model of a LT1 engine and auto transmision. Alternatively, I could develop a model.
Does anyone have a model thwy would share?
Does anyone have the outer dimensions of a LT1 engine?
Are the dimensions the same dimensions as earlier GM 350 or the later LS1?
Thanks
Mutt
Old 04-09-2012, 01:07 PM
DoubleVision's Avatar
The block is identical to the generation 1 350. When you study the LT1 it's obvious, it was directly designed after the Generation 1. except that it's reverse flow cooled so it's got additional coolant ports, the coolant passages on the deck aren't the same as a generation 1 and the water pump on the LT1 is driven off the cam gear. The camshafts between the LT1 and the Generation 1 interchange, the bore and stroke is the same as well. So yeah if you can find one of a generation 1 you should be in the ball park.
Old 04-09-2012, 02:36 PM
Several hotrod sites have confirmed that the LT1 & gen 1 350 will be the same dimensions.
Does anyone have a model or sketch of one?
Just need overall dims, ideally with the location of motor mounts.
Thanks
Mutt
The Outer Limits Chevyjeepster Engine 3 12-14-2011 10:47 AM
Outer cam bearing 19nova69 Engine 8 05-23-2010 07:32 PM
Replacing inner and outer rockers Moon Body - Exterior 7 03-20-2010 05:58 PM
Outer Rocker Work modas Body - Exterior 3 11-01-2006 06:07 PM
what are the outer dimensions of a 426 mech-techie Hotrodders' Lounge 1 06-05-2002 02:06 PM
