-   -   Output shaft wobble (http://www.hotrodders.com/forum/output-shaft-wobble-219681.html)
T Evans 05-21-2012 07:55 PM
Output shaft wobble
I've got a 2004R that I'm putting in a 1950 Jeepster project. Yesterday I measured the drive shaft. When I pulled the slip yoke from the transmission I noticed that the output shaft would move side to side about an eighth of an inch. Is this normal movement without the s/y in place? Thanks for any thoughts.
Crosley 05-21-2012 07:58 PM
yes, the shaft movement is normal with no yoke installed
mmerlinn 05-21-2012 11:27 PM
The yoke is the only support the shaft has. Remove the yoke and you remove the support.
boatbob2 05-22-2012 08:12 AM
Huh??
What is the S/Y???or did you mean S/J (slip joint)
mmerlinn 05-22-2012 10:38 AM
He meant "slip yoke".
