yes, the shaft movement is normal with no yoke installed
At the Bonneville Salt Flats, first gear is known as 130 mph. |
The yoke is the only support the shaft has. Remove the yoke and you remove the support.
Huh??
What is the S/Y???or did you mean S/J (slip joint)
| 700r4 output shaft | JTGochenour | Transmission - Rearend | 1 | 02-08-2012 05:26 PM |
| TH700 output shaft | cu42 | Transmission - Rearend | 5 | 04-21-2009 11:31 AM |
| Tail Shaft Wobble?? | Hoonbash | Transmission - Rearend | 8 | 07-04-2007 08:37 PM |
| TH350 output shaft | Nalehed | Transmission - Rearend | 3 | 06-07-2007 07:11 PM |
| C5 output shaft loose | k2mooch | Transmission - Rearend | 1 | 03-17-2004 04:50 PM |
