Oval or Square Port on my 496 BBC? - Hot Rod Forum : Hotrodders Bulletin Board
View Poll Results: Oval ports or Square on my particular 496 build?
Oval ports all the way, torque baby! 4 80.00%
Square ports, let that baby breathe! 1 20.00%
Voters: 5. You may not vote on this poll
Old 06-02-2010, 07:33 PM
ChevelleSS's Avatar
496 BBC, TH400 12 bolt w/ 3.73
Oval or Square Port on my 496 BBC and more...
Hey guys, I know there are a ton of threads relating to this question, however I am right on the border for cubes to choose between the two so would really appreciate some advice. Please dont flame me too bad lol!
So...
I am upgrading from a pair of oval port gm 781 heads to a set of aluminum oval or square ports. I am considering going with a set of the bare procomps and building them with the Lunati kit designed for my cam along with stainless Manley valves. I will be installing a 496 stroker kit (Eagle) in my 454 and am wondering if a good set of ovals will flow enough to get me to the 550-575 (would looove to crack 600) crank hp range. I am using an Eagle cast crank so will for sure be keeping my rpm below 6500, plus my valve springs are 142/402 so wont take any more rpm than that. Also my intake and cam all all designed for sub 6500 operation. Here are the parts I am using on this build:
496 Eagle cast crank stroker kit
18cc Mahle Forged Dome pisons (10.2 to 1 w/ 118cc chambers)
781 GM oval port heads
Lunati Hyd Roller Cam (241/249 @.050 w/ .625 lift exh/int)
Lunat Street Series Retro Lifters
PRW 1.72 Aluminum Roller Rockers
Edelbrock Air Gap RPM oval port intake
Holley 850 double pumper w/ annulars
1 7/8 Headers, 2 1/2" dual exhaust
TH400 w/ B&M Nitrous Holeshot converter (3000)
12 Bolt posi w/ 3.73 gears
This is a street build w/ the occassional strip use (twice a year or so). I am more concerned with torque and throttle response than peak power at 6000+ so thats why I was leaning towards the oval ports.
Also I was wondering if my mechanical fuel pump that flows 110 gph will be enough for my 496 needs?
What kind of power differences should I expect using oval vs square?
Thanks for all the help guys! Mike
Old 06-02-2010, 08:12 PM
techinspector1's Avatar
Wiki Edits: 326
BOBCRMAN@aol.com likes to start with bare ProComp heads. He should be along in a little to line it all out for you.
As far as fuel delivery, I use an old formula that figures the need, then doubles it to account for pushing against inertia through relatively small lines. For instance, a motor will normally use about 0.5 lbs per hp hour. So, at 600 hp, the motor will use 300 lbs per hour. Gasoline weighs about 6 lbs per gallon, so 300 divided by 6 equals 50 gallons per hour. Doubling that calls for a pump that will deliver 100 gallons per hour.
Old 06-02-2010, 08:26 PM
ChevelleSS's Avatar
Thanks for the advice, much appreciated. I am new here and hope others will chime in on my head dilema along with some power expectations. Here is a pic of my 69 guys, thanks for the hand! Mike
Old 06-03-2010, 01:59 AM
Wiki Edits: 326
bump to top
Old 06-03-2010, 05:06 AM
With that cam and street use I'd go oval.
Old 06-03-2010, 05:43 AM
ChevelleSS's Avatar
Can you enlighten me to your reasons please? Thanks! Mike
Old 06-03-2010, 05:51 AM
BOBCRMAN@aol.com's Avatar
I agree. Oval ports will work great. If you were running a bit more radical cam. Aftermkt heads would be the way to go. I try to use the .660-.680 lift cams. As big blocks like lots of lift..
I did a re fresh on a big chevy for a customer recently. He runs it in a 55 chevy old time gasser. He's getting older ( late sixties) and wanted to "tame down" the old rat. Removed a .700+ cam. Went to a .680 roller cam. Changed from old ported Rect port iron heads to oval aluminum aftermkt. heads (Pro Comp). Dropped compression back a bit.
Just for grins he took the fresh car to the track. It went faster than when it was a serious drag car. He now has brought his big block Jeep to the shop for a "de-tune"....
Old 06-03-2010, 06:27 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Sounds like you're after some serious power. Regardless of heads, you might consider a solid roller cam/lifters.
The BBC has a heavy valvetrain, and decent lift requires a lot of spring pressure to control things.
Old 06-03-2010, 06:51 AM
Rect ports need rpm to breath you gonna turn 7k on the street?...LOL the BBC does have a heavy valvetrain but maybe using 11/32" valve stems instead of 3/8" and titanium retainers lighten it some.What is the rpm range of the cam you speced?
Old 06-03-2010, 07:10 AM
ChevelleSS's Avatar
Its the Lunati Voodo 60213 Hyd Roller Cam. Here is what the website says:
"Hydraulic roller, rough idle. Serious street/strip camshaft. Needs 10.5:1 compression ratio, 3000-3500 RPM stall speed converter and 3.73 or better rear gears. Works well with plate style nitrous systems or smaller superchargers with up to 12 PSI boost.
•Advertised Duration (Int/Exh): 292/300
•Duration @ .050 (Int/Exh): 241/249
•Gross Valve Lift (Int/Exh): .625/.625
•LSA/ICL: 110/106
•Valve Lash (Int/Exh): Hyd/Hyd
•RPM Range: 2600-6200"
I called Lunati direct before my initial setup decisions and they said this cam would be good to 6200. Is this true with my setup? 142/402# valve springs, oval ports, 496 cubes?
Anybody see any mismatches in my setup?
What kind of hp peak and curve would one expect w/ ovals?
Thanks again for the help everybody!
Old 06-03-2010, 08:59 PM
Wiki Edits: 326
Would be true with ANY hydraulic roller profile. The heavy lifter tends to leave the lobe profile at speeds in excess of 6200. It's just a rule of thumb with hydraulic rollers. You want revs, install a solid roller with rev kit springs in the cam valley.
Old 06-04-2010, 05:16 AM
I assume you have someone to check the balance on the assembly right?
Old 06-04-2010, 11:33 AM
ChevelleSS's Avatar
Oh ya, my local machine shop is doing the bore/hone/deck/balance fresh for the 496... Thanks for caring man! LOL!
Old 06-06-2010, 07:04 AM
ChevelleSS's Avatar
Any guesses to my expected hp/quarter times with this setup?
BBC, 396 cast#3856208 rect port head Fastest65 Engine 13 09-13-2008 12:51 PM
Square Port Headers 68NovaSS Engine 0 05-22-2005 12:05 AM
Oval vs. Square Port Heads? Coleman396 Engine 9 07-22-2004 05:07 PM
Big Block Square Port Heads Farmer Engine 2 03-07-2004 04:53 PM
Square or Oval Heads? unstable Engine 4 08-15-2003 06:28 PM
