Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Over Assisted Mopar Steering
Old 06-30-2012, 04:13 PM
jfmmck's Avatar
jfmmck jfmmck is offline
jamie
flow restrictors
There are a couple of different types of valves that reduce the flow rate of the pump. One type is a fitting that screws in at the pump pressure port, they come in different flow rates, you decide which you need (hopefully they fit a Mopar pump). The other type valve plumbs into the pressure and return lines and is adjustable. It's a lot more work and expence to install, but it works with any brand and is infantly adjustable. I belive Summit and Speedway sell both.
