Need a bit more specifics here..do you have an early Ford axle as there is way to do this..main thing is to ditch the spindle mount wheels and install rotors and adapters for the disk calipers and then use a wire wheel with a regular bolt pattern. Mostly a bolt on deal and you will most likely have to change the master cylinder to the proper type..Speedway or TCI likely will have the pieces that you need...
Found our other post and yes change the spindles as well as u yours have had the holes on the stock spindles removed so you will need new spindles as well..measure the kingpin dia as there is a difference and that info helps in finding the right parts..
Definitely a proportioning valve will be needed as well..once you have all that stuff installed we can waalk you thru the adjustment of that thing..
Sam
