over my head - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-08-2012, 02:17 PM
Last journal entry: body
over my head
In over my head...my T has no front brakes....i like the style....motorcycle type spokes and wheels but kinda think really do need to put fronts on it. Any one know anybody around southeastern ohio or wv or ky that could do it or help....i will pay, not looking for handouts
Coach
Old 02-08-2012, 02:32 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Need a bit more specifics here..do you have an early Ford axle as there is way to do this..main thing is to ditch the spindle mount wheels and install rotors and adapters for the disk calipers and then use a wire wheel with a regular bolt pattern. Mostly a bolt on deal and you will most likely have to change the master cylinder to the proper type..Speedway or TCI likely will have the pieces that you need...
Found our other post and yes change the spindles as well as u yours have had the holes on the stock spindles removed so you will need new spindles as well..measure the kingpin dia as there is a difference and that info helps in finding the right parts..
Definitely a proportioning valve will be needed as well..once you have all that stuff installed we can waalk you thru the adjustment of that thing..
Sam
Old 02-08-2012, 05:49 PM
I am dead
Do you know any of the guys on here that are close to me.
I did have new rubber put on the front and i greased the wheel bearings ....wow i was so proud....but that stuff you just said ...no way i dont think. Big thing i guess is i have never taken out king pins at least i think that is what they are called...i have to do that to find out if it is ford or not.
i hate to say this but i will prob sell after a couple of car shows. i hate to do that and if you looked at my pics you will see how pretty she is.
coach
Unable to separate head from block due to head gasket sealer Nostalgia Hotrodding Basics 18 02-02-2011 01:12 PM
14102187 casting 305 head modification,outperform a 350 head ??? Calderone Engine 3 05-10-2009 09:09 AM
head bolts or head studs? head gaskets? thefloyd1973 Engine 9 07-04-2008 09:25 AM
Chevy head 482824?? I cant find ne listing on this head?? 89SDime Engine 3 01-27-2006 08:51 PM
More head questions for the head gurus, seen 305 heads with 2.02's 4speed57 Engine 10 07-13-2005 02:14 AM
