Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - over sized rings on standard pistons
Old 12-12-2012, 05:09 PM
hpete hpete is offline
Ring sets are available .010" oversize. If you have less than .010" taper in your bores and the ring lands are ok in your pistons you can rering a block with standard bores. This is low budget stock replacement stuff not hiperf at all. Also you have to use a glaze breaker hone on the cyl walls, and measure the end gap at the bottom of the cylinders(because their tapered).
