over spray - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-16-2012, 05:21 PM
over spray
I recently painted My 66 Pontiac like 2 days ago,My problem is i had some runs to wet sand out and I got some over spray.I used a very fine metal flake (004) mixed in to clear coat then just plain clear over it.I was wondering If some thing like that could be buffed out and if so,what sort of compound should I use?Im really trying to prevent re-clearing it(I already assembled it so Im hoping I dont haved to basicaly start over.Thanx in advance folks!
Old 10-17-2012, 05:51 AM
Please explain exactly what this "overspray" is. The term overspray usually is meant there is a very light "coat" of paint on something that wasn't suppose to be painted. Like the masking paper wasn't stuck down well and some paint or clear got on the windows or on a panel that wasn't being painted. What exactly are you referring to?
Old 10-17-2012, 06:58 AM
Ok,The over spray is on panels that got like a mist coat because I figures instead of masking,I would allow for some overspray thinking it would be minimum being it was clear coat But instead,it turned out to be pretty noticeable as like a flatter coat ,as compared to being glossy.Does that make sense?
Old 10-17-2012, 07:15 AM
The first thing I would go after it with would be a clay bar, these clay bars are an amazing tool for overspray. Then if that doesn't work you will be cutting and buffing it. Do you plan on sanding (cutting) and buffing it anyway?
Old 10-17-2012, 07:26 AM
I was planning to just do a polish buff because the fine flake I use will loose its color if I color sand or buff thru the clear(I only have 1 good coat of clear on it)I had already sanded a couple runs I had and had to re-paint then re-clear,hence the over spray.I wanted to keep the buffing to a minimum if possible so I dont go down to the flake.
Old 10-17-2012, 09:37 AM
This is what I was talking about. Clay Magic Auto Clay Bars - The Best Auto Detailing Clay Bar for Car Care
It should be done first even if you are sanding and buffing.
Old 10-17-2012, 04:36 PM
Thanks Brian,Ill try that first...Jeff
Old 10-18-2012, 12:45 PM
The good thing is you've probably learned 2 things from this.
1 coat of clear isn't enough to flat and buff and always mask out what you aren't painting.
Old 10-18-2012, 10:10 PM
The problem w/ masking is then Ill have tape lines Ill have to deal with.One last thing about the clay bar Brian.At a guess,how much material will I be taking off?Looks pretty minimal,huh?And yes,the bigger thing I learned is lack of lighting.If I had lit my shop A lot more,It woulda turned out a helluva lot nicer.Me o my...Jeff
Old 10-18-2012, 10:56 PM
Originally Posted by jeffs66 View Post
One last thing about the clay bar Brian.At a guess,how much material will I be taking off?Jeff
Zero, not one single bit. It just "grabs" the stuff on top and removes it.
Old 10-19-2012, 01:04 AM
Sounds like you've been trying to blend the clear ?
You really should be clearing the whole panel then you wouldn't get the overspray
Old 10-19-2012, 01:22 AM
ya I figured I shoulda shot the whole panel but I was runnin out of materials,
Old 10-19-2012, 01:25 AM
Thanks for your input guys but I geuss Ill be repainting this fall....with mega more lighting..lol.Thanx folks..Jeff
Old 10-19-2012, 08:13 AM
Ahhhhhhhh I am missing something, NO that clay bar wouldn't work if you blended out the clear, that requires LIGHTLY buffing. Open blends ALWAYS fail at some point, NOT a good idea. There are very few times when an open blend save any more time than just clearing the whole panel.
Thanks Daz for pointing that out, I missed it.
Old 10-19-2012, 10:59 AM
Yeah,sorry bout that,I thought you understood that.I was just trying to blend with the clear that was already there.I probobly shoulda said "blend".lol Thanks again.I will try the light buff..Jeff
Spray and re-spray...(long one) VWFan Body - Exterior 9 03-17-2011 10:17 PM
K Spray? Coodeville Interior 4 06-16-2010 12:33 PM
Over spray Sully_PA Body - Exterior 5 07-09-2007 03:08 PM
How Much For A Spray? SHIFTY101EASY Body - Exterior 22 01-29-2007 07:30 AM
Over spray kaw550 Body - Exterior 11 06-23-2006 07:00 PM
