Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Over tightened transmission mount bolt
Old 10-09-2012, 06:15 PM
adantessr's Avatar
adantessr adantessr is offline
'23 T-Bucket Pickup
Last wiki edit: Troubleshooting ignition Last photo:
Wiki Edits: 3
You can buy a thread insert kit for the bolt size that you need from your local parts store. The kit will come with a drill bit, a tap, thread inserts and an insert installer. You will then be able to re-install the original bolt after cleaning the aluminum out of the threads. Be careful not to drill to deep. The bit will want to grab in aluminum. A trick that I use is to grind the leading edge of the drill bit flat so that it scrapes the aluminum off instead of cutting it.
The Following User Says Thank You to adantessr For This Useful Post:
0trbo4myCHEVUICK (10-10-2012)
