-   -   Over tightened transmission mount bolt (http://www.hotrodders.com/forum/over-tightened-transmission-mount-bolt-224857.html)
0trbo4myCHEVUICK 10-09-2012 06:06 PM
well i was tightening my TH400 mount to the crossmember and "pop" the bolt falls loose. shreds of metal in the threads. has anyone ever used a tap and die set on a trans case? can i sleeve it? Im trying very hard not to freak out right now ive been dealing with this swap for 3 months now and i just want to drive my friggin truck.
Do i tap it to a bigger size bolt?
poncho62 10-09-2012 06:13 PM
You can put a Heli-coil in it....or, find another tail housing for the trans
adantessr 10-09-2012 06:15 PM
You can buy a thread insert kit for the bolt size that you need from your local parts store. The kit will come with a drill bit, a tap, thread inserts and an insert installer. You will then be able to re-install the original bolt after cleaning the aluminum out of the threads. Be careful not to drill to deep. The bit will want to grab in aluminum. A trick that I use is to grind the leading edge of the drill bit flat so that it scrapes the aluminum off instead of cutting it.
SSedan64 10-10-2012 10:35 AM
The Heli-Coil or Thread-Sert will be much stronger than Tapping to the next larger Bolt size. Either option will work tho'.
0trbo4myCHEVUICK 10-10-2012 01:38 PM
Instead of the heli-coil I ended up threading in a longer bolt with a nut up top. Didnt think there was going to be enough clearance for the nut but what do you know it fits perfectly..
