You can put a Heli-coil in it....or, find another tail housing for the trans
Ontario Rodders |
You can buy a thread insert kit for the bolt size that you need from your local parts store. The kit will come with a drill bit, a tap, thread inserts and an insert installer. You will then be able to re-install the original bolt after cleaning the aluminum out of the threads. Be careful not to drill to deep. The bit will want to grab in aluminum. A trick that I use is to grind the leading edge of the drill bit flat so that it scrapes the aluminum off instead of cutting it.
| The Following User Says Thank You to adantessr For This Useful Post: | ||
0trbo4myCHEVUICK (10-10-2012) | ||
Instead of the heli-coil I ended up threading in a longer bolt with a nut up top. Didnt think there was going to be enough clearance for the nut but what do you know it fits perfectly..
| How much clearance should there be between motor mount and motor mount bolt? | firstgear | Hotrodding Basics | 8 | 03-21-2013 09:10 PM |
| Transmission mount | Babyburr | Transmission - Rearend | 2 | 04-30-2011 09:02 PM |
| C6 Transmission Mount | martin c | Transmission - Rearend | 0 | 06-24-2007 02:20 AM |
| Transmission mount | srfzup | Transmission - Rearend | 3 | 06-03-2004 09:32 AM |
| Transmission mount | arborlis | Transmission - Rearend | 2 | 04-14-2003 06:55 PM |
