Overcharging - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-16-2013, 11:08 AM
Overcharging
My battery is located in the back on my 1966 Glassic Phaeton (31 Phaenton) with heavy duty cable going up front, would this cause my volt meter to read higher than it should?
Old 03-16-2013, 11:17 AM
Bonneville462's Avatar
Bad voltage regulator or it's needs adjusted...
Last year a Summit alternator (10 DN) welded my regulator points together and I had the same condition your describing... I ended up having to replace the alt and the wiring harness...
Old 03-16-2013, 01:30 PM
The volt meter might be inaccurate also. What is it reading? Is it the meter in the dash or a hand held unit? Either way, check the voltage with a multi-meter before you go any further. The cable will only cause a drop in voltage if it isn't big enough. No way will it cause higher voltage.
Old 03-16-2013, 01:51 PM
Charging problem
New alt. New Voltage reg. New Horn relay, still over charging, could the air gap on the voltage reg. need adjusting
Old 03-16-2013, 03:09 PM
How do you know it's overcharging? What is the voltage?
Old 03-16-2013, 06:58 PM
I'd look up the air gap and the point gap in the manual... Every new regulator I ever bought needed adjusted.. On my 64 Bonneville, I set the voltage to 13.5 volts @1500 rpm, the points will last longer and run better..
Old 03-17-2013, 06:59 PM
EOD Guy's Avatar
To me it's not worth the trouble to chase this down...... much easier to convert over to an internal regulated alt, I had such an issue with my old elec system before I convert to an internal and finially I re-wired the car...... no more electrical issues!
Overcharging Mike's31 Electrical 1 01-29-2013 03:48 PM
Overcharging 2010chevy truck Dholcom Electrical 1 02-19-2012 08:22 AM
Is my alternator overcharging? drchip Electrical 7 04-28-2011 08:15 AM
Am I overcharging?? cutsupreme Electrical 4 06-16-2007 05:38 AM
altinator overcharging walkn slow Electrical 2 03-20-2007 10:09 AM
